Java Runtime Environment: which java platform is used and what version
openHAB version: 1.5
Issue of the topic: Could not connect to wifi
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
It took many hours to learn that the Raspberry Pi 0W does not work on channel 10 or 11 of wifi. Once I changed my wifi router settings to another the setup proceeded much smoother. I recommend updating the wifi notes in documentation with this.
Itāll run. Thereās just barely enough RAM for it to work. But you canāt create anything but a very tiny configuration (one or two add-ons) before running out of RAM. Itās also slow as can be.
An RPi 2 or better is the official minimum recommendation. An RPi 0W is weaker in RAM and CPU than an RPi 2 so it is not an officially supported platform. You can try to run on it but we cannot be held responsible for documenting gotchas with unsupported platforms.
NOTE: I do see that the docs were a little misleading on this point. It says āRPi 2 or newerā which isnāt really correct. It should say āRPi 2 or betterā. Iāve submitted a PR to correct the docs.
The Raspberry Pi Zero W is below the minimum recommended specs. The RPi 0W has the same specs as an RPi 1. An RPi 2 is the minimum recommended, RPi 3 or 4 is preferred if going the RPi route.
Yes. And I think one should get an Orange Pi PC or One or Zero instead of RPi Zero W if you want to run OH because they are about equal in performance to RPi2 for price of ZeroW.
Usually itās not cost that drives people to an RPi 0W, itās either thatās what they happen to have on hand or they have a form factor constraint that makes something like the Orange Pi PC or One too big. The Orange Pi Zero has the same major limitation as the RPi 0W, not enough RAM.
OH is primarily RAM constrained, not CPU constrained.
OpenHab v1.2 stated āfull support for RPi0Wā (https://github.com/openhab/openhabian/releases). I assumed incorrectly that versions since would also have that support. I can definitely confirm the running out of RAM on RPi 0W. It has been a frustrating entry point to Openhab.
Itās dangerous to rely on a nearly three year old release note to determine what it or is not currently supported in any software. A release note is a snapshot of the software at as point in time, and as such they are not updated as the software changes and evolves.
