- Platform information:
- Hardware: QNAP
- OS: Linux
- Java Runtime Environment: not sure
- openHAB version:2.2.0 (release build)
I am trying to setup persistence. I have got reasonably far, but am not stuck. My installation will:
- turn on and off a light
- has a mariadb database
- I have manually created the openhab database schema
- configuration to connect to the database and log every single event change
- openhab has created a single ‘items’ table in the schema. This currently has two columns: ItemId and itemname. (Is this correct?)
What could be wrong?
Many thanks, George
My first config file is jbdc.persist
// persistence strategies have a name and definition and are referred to in the "Items" section
Strategies {
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
// if no strategy is specified for an Item entry below, the default list will be used
default = everyChange
* Each line in this section defines for which Item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* Item (excl. the group Item itself).
Items {
// persist the Item state of Heating_Mode and Notifications_Active on every change and restore them from the db at startup
Heating_Mode, Notifications_Active: strategy = everyChange, restoreOnStartup
// additionally, persist all temperature and weather values every hour
* : strategy = everyChange, everyDay, restoreOnStartup
Energyswitch1_Power, Energyswitch2_Power : strategy = everyChange, everyDay, restoreOnStartup
F2_Loft_Light : strategy = everyChange, everyDay, restoreOnStartup
My second config file is jbdc.cfg. I am only including the non-commented out lines.
url=jdbc:mariadb://192.168.0.15:3306/openhab
# required database user
user=root
# required database password
password=admin
The logs are showing it is connecting to the database.
2019-05-11 20:40:44.579 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2019-05-11 20:40:45.842 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::logTime: 'pingDB':
afterAccess = 1259 ms
timeAverage50 = 1259 ms
timeAverage100 = 1259 ms
timeAverage200 = 1259 ms
afterAccessMin = 1259 ms
afterAccessMax = 1259 ms
1000Statements = 0 sec
statementCount = 1
2019-05-11 20:40:45.917 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::logTime: 'doCreateItemsTableIfNot':
afterAccess = 49 ms
timeAverage50 = 654 ms
timeAverage100 = 654 ms
timeAverage200 = 654 ms
afterAccessMin = 49 ms
statementCount = 2
2019-05-11 20:40:45.937 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::logTime: 'getItemIDTableNames':
afterAccess = 16 ms
timeAverage50 = 441 ms
timeAverage100 = 441 ms
timeAverage200 = 441 ms
afterAccessMin = 16 ms
statementCount = 3
