After having gotten the zwave binding to work on FreeBSD I’ve run into the next problem. I can’t get /rest started. I’ve found the following possibly relevant discussion on github,
but the issue was closed and the proposed solution does not work for me. If I remove the servicediscovery bundle the REST api does not even attempt to start.
When I leave the servicediscovery bundle in it does attempt to start, but keeps restarting ad infinitum. When I display the list of bundles in the console (list), it tells me the bundle is “unsatisfied”. A “list -c” tells me (among many other things):
No instances were created because: Can not activate instance of component org.openhab.io.rest.RESTApplication. The activation throws: java.lang.NullPointerException
and a class not found exception:
18:06:19.848 [WARN ] [sphere.cpr.AtmosphereFramework:1097 ] -
java.lang.ClassNotFoundException: org.atmosphere.interceptor.DefaultHeadersInterceptor
Anyone have any pointers on where to start to look?
NB Here is the (start_debug.sh) output I get when I start openhab:
17:21:38.813 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
17:21:38.981 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
17:21:39.051 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
17:21:39.053 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
17:21:39.059 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
17:21:39.064 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) ‘openHAB-job-scheduler’ with instanceId ‘NON_CLUSTERED’
Scheduler class: ‘org.quartz.core.QuartzScheduler’ - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool ‘org.quartz.simpl.SimpleThreadPool’ - with 2 threads.
Using job-store ‘org.quartz.simpl.RAMJobStore’ - which does not support persistence. and is not clustered.
17:21:39.066 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: ‘./etc/quartz.properties’
17:21:39.068 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
17:21:39.070 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
17:21:39.082 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘/usr/local/openhab-1.8.0-SNAPSHOT/configurations/openhab_default.cfg’.
17:21:39.531 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘/usr/local/openhab-1.8.0-SNAPSHOT/configurations/openhab.cfg’.
17:21:39.688 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at ‘/usr/local/openhab-1.8.0-SNAPSHOT/webapps/static/uuid’ with content ‘3c556d7c-fdf0-4123-a01a-bc21215f6f51’
17:21:39.694 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file ‘/usr/local/openhab-1.8.0-SNAPSHOT/webapps/static/version’ with content ‘1.8.0’
17:21:39.696 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.0).
17:21:39.797 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
17:21:43.695 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered ‘persistence’ configuration parser
17:21:43.795 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
17:21:43.964 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
17:21:44.072 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
17:21:44.094 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
17:21:44.202 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service…
17:21:44.220 [ERROR] [o.o.i.s.i.DiscoveryServiceImpl:55 ] - Invalid argument
17:21:44.729 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered ‘item’ configuration parser
17:21:45.157 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider ‘GenericItemProvider’ has been added.
17:21:47.746 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered ‘sitemap’ configuration parser
17:21:48.282 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
17:21:48.511 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
17:21:48.636 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
17:21:48.641 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$BytecodeBasedAnnotationProcessor being used
17:21:48.746 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
17:21:48.890 [INFO ] [sphere.cpr.AtmosphereFramework:1891 ] - Auto detecting atmosphere handlers /WEB-INF/classes/
17:21:48.951 [INFO ] [sphere.cpr.AtmosphereFramework:639 ] - Installed AtmosphereHandler org.atmosphere.handler.ReflectorServletProcessor mapped to context-path /* and Broadcaster Class org.atmosphere.jersey.JerseyBroadcaster
17:21:48.953 [INFO ] [sphere.cpr.AtmosphereFramework:1945 ] - Auto detecting WebSocketHandler in /WEB-INF/classes/
17:21:48.957 [INFO ] [sphere.cpr.AtmosphereFramework:1602 ] - Installed WebSocketProtocol org.atmosphere.websocket.protocol.SimpleHttpProtocol
17:21:49.155 [INFO ] [.a.h.ReflectorServletProcessor:103 ] - Installing Servlet com.sun.jersey.spi.container.servlet.ServletContainer
17:21:49.625 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:815 ] - Initiating Jersey application, version ‘Jersey: 1.18.1 02/19/2014 03:28 AM’
17:21:49.634 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:826 ] - Adding the following classes declared in META-INF/services/jersey-server-components to the resource configuration:
class org.atmosphere.jersey.AtmosphereResourceConfigurator
17:21:49.921 [INFO ] [j.s.i.a.DeferredResourceConfig:101 ] - Instantiated the Application class org.openhab.io.rest.RESTApplication
17:21:52.631 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘Louiseval.sitemap’
17:21:53.504 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model ‘Louiseval.items’
17:21:53.751 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model ‘Louiseval.items’
17:21:53.768 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model ‘Louiseval.items’
17:21:54.714 [INFO ] [sphere.cpr.AtmosphereFramework:2435 ] - AtmosphereInterceptor CORS Interceptor Support will always be executed first
17:21:54.716 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor CORS Interceptor Support with priority FIRST_BEFORE_DEFAULT
17:21:54.719 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Default Response’s Headers Interceptor with priority AFTER_DEFAULT
17:21:54.725 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Android Interceptor Support with priority AFTER_DEFAULT
17:21:54.729 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor SSE Interceptor Support with priority AFTER_DEFAULT
17:21:54.732 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor JSONP Interceptor Support with priority AFTER_DEFAULT
17:21:54.739 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Atmosphere JavaScript Protocol with priority AFTER_DEFAULT
17:21:54.742 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Browser disconnection detection with priority AFTER_DEFAULT
17:21:54.756 [INFO ] [sphere.cpr.AtmosphereFramework:935 ] - Using EndpointMapper class org.atmosphere.util.DefaultEndpointMapper
17:21:54.761 [WARN ] [sphere.cpr.AtmosphereFramework:941 ] - No BroadcasterCache configured. Broadcasted message between client reconnection will be LOST. It is recommended to configure the org.atmosphere.cache.UUIDBroadcasterCache
17:21:54.764 [INFO ] [sphere.cpr.AtmosphereFramework:949 ] - Default Broadcaster Class: org.atmosphere.jersey.JerseyBroadcaster
17:21:54.766 [INFO ] [sphere.cpr.AtmosphereFramework:950 ] - Broadcaster Polling Wait Time 100
17:21:54.768 [INFO ] [sphere.cpr.AtmosphereFramework:951 ] - Shared ExecutorService supported: true
17:21:54.770 [INFO ] [sphere.cpr.AtmosphereFramework:958 ] - Messaging Thread Pool Size: 10
17:21:54.772 [INFO ] [sphere.cpr.AtmosphereFramework:968 ] - Async I/O Thread Pool Size: 10
17:21:54.775 [INFO ] [sphere.cpr.AtmosphereFramework:979 ] - Using BroadcasterFactory: org.atmosphere.cpr.DefaultBroadcasterFactory
17:21:54.777 [INFO ] [sphere.cpr.AtmosphereFramework:980 ] - Using WebSocketProcessor: org.atmosphere.websocket.DefaultWebSocketProcessor
17:21:54.779 [INFO ] [sphere.cpr.AtmosphereFramework:990 ] - Invoke AtmosphereInterceptor on WebSocket message true
17:21:54.780 [INFO ] [sphere.cpr.AtmosphereFramework:991 ] - HttpSession supported: false
17:21:54.782 [INFO ] [sphere.cpr.AtmosphereFramework:993 ] - Atmosphere is using DefaultAtmosphereObjectFactory for dependency injection and object creation
17:21:54.784 [INFO ] [sphere.cpr.AtmosphereFramework:994 ] - Atmosphere is using async support: org.atmosphere.container.JettyAsyncSupportWithWebSocket running under container: jetty/8.1.3.v20120522 with WebSocket enabled.
17:21:54.790 [INFO ] [sphere.cpr.AtmosphereFramework:996 ] - Atmosphere Framework 2.2.5 started.
17:21:54.793 [INFO ] [sphere.cpr.AtmosphereFramework:998 ] -
For Atmosphere Framework Commercial Support, visit
http://www.async-io.org/ or send an email to support@async-io.org
17:21:54.797 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
17:21:54.811 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
17:21:54.871 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
17:21:54.893 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
17:21:54.895 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$BytecodeBasedAnnotationProcessor being used
17:21:54.924 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
17:21:55.022 [INFO ] [sphere.cpr.AtmosphereFramework:1891 ] - Auto detecting atmosphere handlers /WEB-INF/classes/
17:21:55.042 [INFO ] [sphere.cpr.AtmosphereFramework:639 ] - Installed AtmosphereHandler org.atmosphere.handler.ReflectorServletProcessor mapped to context-path /* and Broadcaster Class org.atmosphere.jersey.JerseyBroadcaster
17:21:55.043 [INFO ] [sphere.cpr.AtmosphereFramework:1945 ] - Auto detecting WebSocketHandler in /WEB-INF/classes/
17:21:55.047 [INFO ] [sphere.cpr.AtmosphereFramework:1602 ] - Installed WebSocketProtocol org.atmosphere.websocket.protocol.SimpleHttpProtocol
17:21:55.061 [INFO ] [.a.h.ReflectorServletProcessor:103 ] - Installing Servlet com.sun.jersey.spi.container.servlet.ServletContainer
17:21:55.071 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:815 ] - Initiating Jersey application, version ‘Jersey: 1.18.1 02/19/2014 03:28 AM’
17:21:55.076 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:826 ] - Adding the following classes declared in META-INF/services/jersey-server-components to the resource configuration:
17:21:55.150 [INFO ] [j.s.i.a.DeferredResourceConfig:101 ] - Instantiated the Application class org.openhab.io.rest.RESTApplication
^C17:21:57.022 [INFO ] [sphere.cpr.AtmosphereFramework:2435 ] - AtmosphereInterceptor CORS Interceptor Support will always be executed first
17:21:57.024 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor CORS Interceptor Support with priority FIRST_BEFORE_DEFAULT
17:21:57.026 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Default Response’s Headers Interceptor with priority AFTER_DEFAULT
17:21:57.028 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Android Interceptor Support with priority AFTER_DEFAULT
17:21:57.030 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor SSE Interceptor Support with priority AFTER_DEFAULT
17:21:57.032 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor JSONP Interceptor Support with priority AFTER_DEFAULT
17:21:57.033 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Atmosphere JavaScript Protocol with priority AFTER_DEFAULT
17:21:57.035 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Browser disconnection detection with priority AFTER_DEFAULT
17:21:57.037 [INFO ] [sphere.cpr.AtmosphereFramework:935 ] - Using EndpointMapper class org.atmosphere.util.DefaultEndpointMapper
17:21:57.039 [WARN ] [sphere.cpr.AtmosphereFramework:941 ] - No BroadcasterCache configured. Broadcasted message between client reconnection will be LOST. It is recommended to configure the org.atmosphere.cache.UUIDBroadcasterCache
17:21:57.040 [INFO ] [sphere.cpr.AtmosphereFramework:949 ] - Default Broadcaster Class: org.atmosphere.jersey.JerseyBroadcaster
17:21:57.041 [INFO ] [sphere.cpr.AtmosphereFramework:950 ] - Broadcaster Polling Wait Time 100
17:21:57.043 [INFO ] [sphere.cpr.AtmosphereFramework:951 ] - Shared ExecutorService supported: true
17:21:57.044 [INFO ] [sphere.cpr.AtmosphereFramework:958 ] - Messaging Thread Pool Size: 10
17:21:57.046 [INFO ] [sphere.cpr.AtmosphereFramework:968 ] - Async I/O Thread Pool Size: 10
17:21:57.047 [INFO ] [sphere.cpr.AtmosphereFramework:979 ] - Using BroadcasterFactory: org.atmosphere.cpr.DefaultBroadcasterFactory
17:21:57.049 [INFO ] [sphere.cpr.AtmosphereFramework:980 ] - Using WebSocketProcessor: org.atmosphere.websocket.DefaultWebSocketProcessor
17:21:57.051 [INFO ] [sphere.cpr.AtmosphereFramework:990 ] - Invoke AtmosphereInterceptor on WebSocket message true
17:21:57.052 [INFO ] [sphere.cpr.AtmosphereFramework:991 ] - HttpSession supported: false
17:21:57.054 [INFO ] [sphere.cpr.AtmosphereFramework:993 ] - Atmosphere is using DefaultAtmosphereObjectFactory for dependency injection and object creation
17:21:57.055 [INFO ] [sphere.cpr.AtmosphereFramework:994 ] - Atmosphere is using async support: org.atmosphere.container.JettyAsyncSupportWithWebSocket running under container: jetty/8.1.3.v20120522 with WebSocket enabled.
17:21:57.056 [INFO ] [sphere.cpr.AtmosphereFramework:996 ] - Atmosphere Framework 2.2.5 started.
17:21:57.058 [INFO ] [sphere.cpr.AtmosphereFramework:998 ] -
17:21:57.059 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
and then eventually
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[na:1.8.0_60]
at org.atmosphere.util.IOUtils.loadClass(IOUtils.java:309) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.configureAtmosphereInterceptor(AtmosphereFramework.java:1094) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.init(AtmosphereFramework.java:892) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.init(AtmosphereFramework.java:780) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.configureFramework(AtmosphereServlet.java:101) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.init(AtmosphereServlet.java:80) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.init(ServletRegistration.java:49) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.registerServlet(ProxyServlet.java:179) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.registerServlet(HttpServiceImpl.java:66) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.openhab.io.habmin.HABminApplication.activate(HABminApplication.java:179) [bundlefile:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_60]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_60]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_60]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_60]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:343) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
