i have a Problem with my temperature values comming from knx.
I am running on OH 2.3 with the knx binding 1.12.0
On my bus monitor the temp value 21,1 is send, but in the OH Log the value looks like this.
But it also sometimes work - as you can also see in the log.
2018-10-09 14:41:12.366 [ome.event.ItemCommandEvent] - Item 'Temperatur_1' received command 21.199999999999999289457264239899814128875732421875
2018-10-09 14:41:12.434 [vent.ItemStateChangedEvent] - Temperatur_1 changed from NULL to 21.199999999999999289457264239899814128875732421875
2018-10-09 14:42:30.855 [ome.event.ItemCommandEvent] - Item 'Temperature_2' received command 22
2018-10-09 14:42:30.870 [vent.ItemStateChangedEvent] - Temperature_2 changed from NULL to 22
The items are configured as number.
Number Temperatur_1 "Raumtemperatur [[%.2f °C]" <temperature> (CH_1) {knx="9.001:3/0/0"}
