I probably made a mistake and configured a Time Zone in Paper UI - Configuration - System
Now I have a huge number of errors on startup, the most relevant seems to be this one:
[ERROR] [org.eclipse.smarthome.core ] - [org.eclipse.smarthome.core.internal.i18n.I18nProviderImpl(50)] The activate method has thrown an exception java.lang.ClassCastException: java.lang.String cannot be cast to java.time.ZoneId
I cannot revert the change through Paper UI. Any other option? Karaf console?
I can confirm it.
After the upgrade to 1063 I get the same messages.
Unfortunately I do not come back to a stable version.
Is there a way / trick, how I get back into a stable assignment?
I use openhabian and have already tried over the config to change STABLE 2.1, unfortunately without success.
Yep, seems to be the same that hit me. Just for the record though, I was on 2.1 stable. Is it a strange coincidence that nobody has seen this until now and then suddenly two users with completely different versions encounter it at the same day?
That solves the problem, thanks!
Initially I tried to solve this on my own, I found that file and deleted just [something], that was obviously not enough.
