rule "Door Sensor OPEN"
Item DoorSensor changed to OPEN
sendTelegram("XXXXXX","Main Door "+ DoorSensor.state)
executeCommandLine("XXXXX")
Gateway_Brightness.sendCommand(100)
sendCommand(Gateway_Volume, 40)
sendCommand(Gateway_Sound, 10)
createTimer(now.plusSeconds(10), [|
sendCommand(Gateway_Sound, 10000)
sendCommand(Gateway_Volume, 0)
Gateway_Brightness.sendCommand(0)
rule "Door Sensor CLOSED"
Item DoorSensor changed to CLOSED
sendTelegram("XXXXXXX","Main Door "+ DoorSensor.state)
I have configured the Xiaomi App to show a notification when the door opens.
Sometimes the sensor doesn’t fire the events with openHAB, but it reports notifications with the Xiaomi App.
Does anyone know why this happen?
[UPDATE]
I’m attaching two videos: are from the same moment. You can see the sensor does not report and later it starts reporting… This is strange right?
What I’ve tried now is just only to bind the item and see in the log if it reports the item status. As you can see is not working always…
No rules nor items defined, just the PaperUI binding.
2018-08-01 15:18:07.546 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:07.567 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T11:05:27.822+0200 to 2018-08-01T15:18:07.541+0200
2018-08-01 15:18:09.358 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:10.620 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:10.626 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:07.541+0200 to 2018-08-01T15:18:10.590+0200
2018-08-01 15:18:11.402 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:14.045 [vent.ItemStateChangedEvent] - MotionStatus2 changed from ON to OFF
2018-08-01 15:18:17.377 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:17.388 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:10.590+0200 to 2018-08-01T15:18:17.363+0200
2018-08-01 15:18:18.395 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:19.020 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:19.027 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:17.363+0200 to 2018-08-01T15:18:18.989+0200
2018-08-01 15:18:20.034 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:20.596 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:20.599 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:18.989+0200 to 2018-08-01T15:18:20.574+0200
2018-08-01 15:18:21.239 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:25.635 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:25.643 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:20.574+0200 to 2018-08-01T15:18:25.625+0200
2018-08-01 15:18:29.875 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:30.635 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:30.643 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:25.625+0200 to 2018-08-01T15:18:30.618+0200
2018-08-01 15:18:31.428 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:31.977 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:18:31.985 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:30.618+0200 to 2018-08-01T15:18:31.958+0200
2018-08-01 15:18:32.654 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:18:33.511 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 140.0 to 151.0
2018-08-01 15:18:33.528 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:17:33.332+0200 to 2018-08-01T15:18:33.498+0200
2018-08-01 15:19:33.588 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 151.0 to 24.0
2018-08-01 15:19:33.619 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:18:33.498+0200 to 2018-08-01T15:19:33.547+0200
2018-08-01 15:19:44.588 [vent.ItemStateChangedEvent] - MotionStatus1 changed from ON to OFF
2018-08-01 15:20:33.803 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 24.0 to 156.0
2018-08-01 15:20:33.821 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:19:33.547+0200 to 2018-08-01T15:20:33.755+0200
2018-08-01 15:21:34.087 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 156.0 to 282.0
2018-08-01 15:21:34.118 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:20:33.755+0200 to 2018-08-01T15:21:34.047+0200
2018-08-01 15:22:34.169 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 282.0 to 19.0
2018-08-01 15:22:34.206 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:21:34.047+0200 to 2018-08-01T15:22:34.131+0200
2018-08-01 15:23:03.214 [vent.ItemStateChangedEvent] - TemperatureValue changed from 23.989999771118164 to 24.270000457763672
2018-08-01 15:23:03.269 [vent.ItemStateChangedEvent] - HumidityValue changed from 74.05999755859375 to 74.83999633789062
2018-08-01 15:23:12.375 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:23:12.388 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:18:31.958+0200 to 2018-08-01T15:23:12.353+0200
2018-08-01 15:23:12.659 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:23:12.860 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:23:12.871 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:23:12.353+0200 to 2018-08-01T15:23:12.832+0200
2018-08-01 15:23:13.236 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:23:34.279 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_latency changed from 19.0 to 51.0
2018-08-01 15:23:34.327 [vent.ItemStateChangedEvent] - network_pingdevice_10_0_0_85_lastseen changed from 2018-08-01T15:22:34.131+0200 to 2018-08-01T15:23:34.237+0200
2018-08-01 15:23:40.831 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:23:40.840 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:23:12.832+0200 to 2018-08-01T15:23:40.809+0200
2018-08-01 15:23:41.958 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
2018-08-01 15:23:42.823 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from CLOSED to OPEN
2018-08-01 15:23:42.833 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_lastOpened changed from 2018-08-01T15:23:40.809+0200 to 2018-08-01T15:23:42.782+0200
2018-08-01 15:23:43.797 [vent.ItemStateChangedEvent] - mihome_sensor_magnet_158d000213392e_isOpen changed from OPEN to CLOSED
logInfo("___","rule Door Sensor OPEN"
logInfo("___","rule Door Sensor CLOSED"
and post please, the log that the rule-file was refreshed correctly (and the folowing lines).
2018-08-01 14:31:57.557 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'xxx.rules'
2018-08-01 16:05:23.257 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2018-08-01 16:05:34.796 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor OPEN
2018-08-01 16:05:35.127 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'default.rules', using it anyway:
The value of the local variable ts is not used
2018-08-01 16:05:35.363 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'default.rules'
2018-08-01 16:05:41.309 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor CLOSED
2018-08-01 16:05:43.655 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor OPEN
2018-08-01 16:05:44.384 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor CLOSED
2018-08-01 16:05:44.782 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor OPEN
2018-08-01 16:05:45.388 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor CLOSED
2018-08-01 16:05:45.573 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor OPEN
2018-08-01 16:05:46.136 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor CLOSED
2018-08-01 16:05:46.315 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor OPEN
2018-08-01 16:05:46.737 [INFO ] [g.eclipse.smarthome.model.script.___] - rule Door Sensor CLOSED
The problem I have is that sometimes rules are not executed as shown in the video. And this behavior is random. It can be something with the xiaomi hab?
Thanks for your reply @hr3.
That’s my first post with the video attached… Sometimes state changes and sometimes not…
I don’t know how to debug this issue…
I have pretty similar problem, that you did. Sometimes my sensor just doesn’t trigger OH, but it works correctly in Mi Home App. Though I don’t think this is the problem with high latency, because I can controll other devices in my home via the Gateway without any problem. The door sensor is the only problem here.
