[SOLVED] Xiaomi Humidity Sensor Read Values in Rules
Hi
Sorry for this stupid question but I’m running nuts…
I have different Xiaomi Sensors attached to Openhab 2.3. I configured them manually in things and items files due to backup reasons.
One is defined as follows
Number:Dimensionless Xi_HT_Schlafzimmer_Humidity “Schlafzimmer” (gHumidity) { channel=“mihome:sensor_ht:xxxx:humidity” }
It shows correct values in my sitemap. BUT in my rule it seems to be not read… I’m wondering whether it is because of Number:Dimensionless
// Rule für Oskar Little im Schlafzimmer
rule “Oskar little ON wenn Feuchtigkeit im Schlafzimmer zu niedrig”
Item Xi_HT_Schlafzimmer_Humidity changed
if (Xi_HT_Schlafzimmer_Humidity < 50) {
if (MyStr_Switch03_Switch.state == OFF) {
MyStr_Switch03_Switch.sendCommand(ON)
sendBroadcastNotification(“Oskar Little im Schlafzimmer wurde eingeschaltet”)
else {
if (MyStr_Switch03_Switch.state == ON) {
MyStr_Switch03_Switch.sendCommand(OFF)
I thing the statement if (Xi_HT_Schlafzimmer_Humidity < 50) is not correct somehow but I’m not able to resolve it. if (Xi_HT_Schlafzimmer_Humidity.state < 50) does not help either.
Can anyone help?
Please use the code fences!
rule "Oskar little ON wenn Feuchtigkeit im Schlafzimmer zu niedrig"
    var humidity = Xi_HT_Schlafzimmer_Humidity.state as Number
    logInfo("Xi_HT_Schlafzimmer_Humidity: ", humidity.toString)
    if (humidity < 50) {
    else {
thank you a lot for you immediate help… I’m going to try this!
Jan
Thank you a lot, works fine!
Jan
Unfortunately it does not work completely…
Regardless of the value of Xi_HT_Schlafzimmer_Humidity resp. humidityr2, always the first IF statement is entered, never the second. Therefore the value of humidityr2 must be always below 45… even if the value is shown as 48 % etc…
Therefore I assume, that there must bei a problem with the value conversion. Maybe the value is in percentage, even if the conversion is made as number etc.
Has anyone a clue?
    var humidityr2 = (Xi_HT_Schlafzimmer_Humidity.state as Number)
    logInfo("Xi_HT_Schlafzimmer_Humidity: ", humidityr2.toString)
    if (humidityr2 < 45) {
        sendBroadcastNotification("Feuchtigkeit Schlafzimmer unter 45%; Einschaltsequenz wurde eingeleitet")
            sendBroadcastNotification("Oskar little im Schlafzimmer wurde eingeschaltet")
    if (humidityr2 > 47) {
        sendBroadcastNotification("Feuchtigkeit Schlafzimmer über 47%; Ausschaltsequenz wurde eingeleitet")
            sendBroadcastNotification("Oskar little im Schlafzimmer wurde ausgeschaltet")
Thanks a lot
Jan
Try that:
var humidityr2 = (Xi_HT_Schlafzimmer_Humidity.state as QuantityType<Number>).doubleValue
Hi Vincent
Thanks a lot for your Help. I will try your hint with the next rule. I did it like this now
    if (humidityr2 < 0.45) {
    if (humidityr2 > 0.48) {
I just divided the limit values by 100 (as for percent) and it seems that it works now.
Jan
