I prefer to setup everything in config files rather than paper UI…
Is there any way to find out the ids of my sensors so I can put them in the things file?
I had to use the discover option in paper UI to find out the details of the bridge…
Okay… Solved…
I used the discover to find the bridge, did not add it through paperUI… Added the bridge to the xiaomi.things file and then once openHAB had processed the changes to that new file I was able to use the discover tool to find the sensors and see their IDs which I can now add to the things fiel
HaHa… Except I’ve got 4 temp sensors and I don’t know which one is which…
Put one in your hand and see which ones temp starts rising.
Yup eventually did that but had to use a hair dryer as some were already stuck to the wall…
