[SOLVED] Xiaomi Valetudo Zone Cleanup MQTT Command
Directly with the binding it works like this for me:
Items:
Switch XiaomiRobotVacuum1SStartCleaning_Proxy "Zone starten []"
String XiaomiRobotVacuum1SActionsCommands "Execute command" {channel="miio:vacuum:0F8F154D:actions#commands"}
Group gVacClean "Staubsauger"
Switch VacAll_Proxy "Alles" (gVacClean,gRestore)
Switch VacKit_Proxy "Küche" (gVacClean,gRestore)
Switch VacWz_Proxy "Wohnzimmer" (gVacClean,gRestore)
Switch VacFlu_Proxy "Flur" (gVacClean,gRestore)
Switch VacAbstell_Proxy "Abstellraum" (gVacClean,gRestore)
Switch VacLR_Bad1_Proxy "Badezimmer" (gVacClean,gRestore)
Rule:
rule "start vaccuum"
    Item XiaomiRobotVacuum1SStartCleaning_Proxy received command
     if (receivedCommand==ON) {
        if (gVacClean.members.filter[r|r.state == ON].size != 0) {
        sCoordinates = ""
        gVacClean.members.filter[r|r.state == ON].forEach[r|
            sCoordinates=sCoordinates + transform("MAP","vacuum.map",r.label) + ","
        sCoordinates = sCoordinates.substring(0,sCoordinates.length - 1)
        if(VacAll_Proxy.state == ON) sCoordinates=transform("MAP","vacuum.map","Alles")
        XiaomiRobotVacuum1SActionsCommands.sendCommand("app_zoned_clean["+sCoordinates+"]")
     else  {
        XiaomiRobotVacuum1SActionsCommands.sendCommand("app_charge")
vacuum.map
Alles=[19750,24500,30000,33300,1]
Küche=[19750,28500,24700,33300,1]
Wohnzimmer=[26200,24500,30000,28500,1],[24800,28500,30000,33300,1]
Flur=[22700,24500,26000,28500,1]
Abstellraum=[19500,27000,22500,28500,1]
Badezimmer=[19750,24500,22500,26300,1]
Code snippets are from this post:
