Firstly, all aspects of the switch reporting values are working exactly as expected.
Here are the items:
// ServerRack Z-Wave Aeotec Smart Switch 6
Switch GF_ServerRack_ "Server Rack" <poweroutlet> (GF_ServerRack, gPower, gPowerGF, gSmartSwitch) { channel="zwave:device:0187d957:node12:switch_binary" }
Number GF_ServerRack_kWh "Server Rack [%.3f kWh]" (GF_ServerRack) { channel="zwave:device:0187d957:node12:meter_kwh" }
Number GF_ServerRack_kWh_Yesterday "Server Rack (Yesterday) [%.3f kWh]" (GF_ServerRack)
Number GF_ServerRack_Amps "Server Rack [%.1f A]" (GF_ServerRack) { channel="zwave:device:0187d957:node12:meter_current" }
Number GF_ServerRack_Volts "Server Rack [%.0f v]" (GF_ServerRack) { channel="zwave:device:0187d957:node12:meter_voltage" }
Number GF_ServerRack_Power "Server Rack [%.0f w]" (GF_ServerRack) { channel="zwave:device:0187d957:node12:meter_watts" }
Switch GF_ServerRack_Reset "Server Rack Reset" (GF_ServerRack) { channel="zwave:device:0187d957:node12:meter_reset", expire="5s,state=OFF" }
Color GF_ServerRack_Color "Server Rack Colour" (GF_ServerRack) { channel="zwave:device:0187d957:node12:color_color" }
And all works perfectly - For testing I have added the group to the sitemap and use the BasicUI, changing the switch in BasicUI for the ‘Reset’ function zeros out the kWh value as expected. However attempting to do the same through a rule does not work.
Rule:
logInfo("smartSwitch.rules", "Resetting Power Usage & recording Yesterdays usage")
GF_ServerRack_kWh_Yesterday.postUpdate(GF_ServerRack_kWh.state)
GF_ServerRack_Reset.postUpdate(ON)
On the rule triggering (and watching on PaperUI) The Reset switch is triggered, the log viewer also shows this, however the kWh value does not get reset.
I’m, obviously, missing something obvious but so far cannot see what it is. Any assistance would be greatly received!
