It looks like I’m having a lot of connection problems? Just a few are green.
How can I fix that? Moving the host closer to the shutter is not an option…
The strange thing is:
Node 8 and 9 are physicaly close together: around 20 cm.
Currently I’m using this stick:
I’m thinking about to switch to the follwing stick:
How can I move the stick wihtout loosing the attached node?
I have no reason to believe that switching to a different controller will improve this.
Also, keep in mind that this map is the map of neighbors and does not necessarily reflect the paths that actual messages take. And the red arrows do not indicate connection problems. I’m not positive about this, but I believe the red arrows are showing non-reciprocal neighbors. For example, 2 is listing 1 as a neighbor but 1 does not list 2 as a neighbor.
Now I do agree, this map does not look healthy. I’m just not sure that replacing the controller would fix your problems. It might. But when I had a similar problem, I added another mains powered device a little closer to the controller to create more solid paths to the controller for the other nodes and everything started to work great.
