[SOLVED] Z wave command info in 2.2
Hi
I used DateTime Node2 “Node2 Update [%1$ta %1$td-%1$tm %1$tr]” (persist) {zwave=“2:command=INFO,item=LAST_UPDATE”} in openhab 1x.
Appreciate if you could help me with the same for openhab 2x. I am not sure how to get info details for z wave node
thanks
Appreciate all the help
This is not available in OH2. There has been much discussion about last update times, and as this isn’t really a ZWave issue it’s not added to the binding.
Thank you Chris
