My fault, wrong subject. I mixed to packaging. The device is FGD-212. It is recognised correct but the firmware is 3.5
I looked in the database from chris and there are two entries for this devices. One with firmware lower then 3.5 and one with higher then 3.5. But my device has 3.5 Not covered by the database.
Since the one is ‘All up to 3.4’ where max firmware is set to 3.4, and the other is ‘All after 3.5’ where the min firmware is set to 3.5, I think your assumption is correct that the value is included.
I made some more tests and let the device run for some hours. I receive datas for some of the items, but some are the same, some I don’t know?
It looks the channels with 1 at the end are the right one.
I will ignore this one’s, looks like the same as the items with ending 1:
Dimmer01_Watts
Dimmer01_Power
Watts1 and Power1 looks like get the same values. I will use only power1 and kwh1
2019-02-23 10:13:02.275 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from NULL to 19.6
2019-02-23 10:13:08.247 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 19.6 to 98.4
2019-02-23 10:17:14.177 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 98.4 to 69.4
2019-02-23 10:17:24.117 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 69.4 to 0.6
2019-02-23 10:17:39.049 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 0.6 to 5.9
2019-02-23 10:17:48.986 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 5.9 to 97.1
2019-02-23 10:17:50.996 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 97.1 to 75.1
2019-02-23 10:17:55.966 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 75.1 to 73.9
2019-02-23 10:25:25.133 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 73.9 to 9.2
2019-02-23 10:25:35.081 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 9.2 to 0.6
2019-02-23 11:16:58.222 [vent.ItemStateChangedEvent] - Dimmer01_kwh1 changed from NULL to 0.02
2019-02-23 11:53:21.431 [vent.ItemStateChangedEvent] - Dimmer01_kwh changed from NULL to 0.02
2019-02-23 11:53:21.474 [vent.ItemStateChangedEvent] - Dimmer01_Watts changed from NULL to 0.6
2019-02-23 11:53:21.660 [vent.ItemStateChangedEvent] - Dimmer01_Watts1 changed from NULL to 0.6
2019-02-23 14:17:29.638 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 0.6 to 4.1
2019-02-23 14:17:30.601 [vent.ItemStateChangedEvent] - Dimmer01_Power changed from 0.6 to 4.1
2019-02-23 14:17:30.701 [vent.ItemStateChangedEvent] - Dimmer01_Watts changed from 0.6 to 4.1
2019-02-23 14:17:30.874 [vent.ItemStateChangedEvent] - Dimmer01_Watts1 changed from 0.6 to 4.1
2019-02-23 14:17:34.612 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 4.1 to 16.7
2019-02-23 14:18:32.375 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 16.7 to 14.9
2019-02-23 14:18:37.360 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 14.9 to 13.3
2019-02-23 14:18:47.302 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 13.3 to 0.6
2019-02-23 14:20:52.779 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 0.6 to 30
2019-02-23 14:20:53.054 [vent.ItemStateChangedEvent] - Dimmer01_Power changed from 4.1 to 30
2019-02-23 14:20:53.149 [vent.ItemStateChangedEvent] - Dimmer01_Watts changed from 4.1 to 30
2019-02-23 14:20:53.332 [vent.ItemStateChangedEvent] - Dimmer01_Watts1 changed from 4.1 to 30
2019-02-23 14:20:57.757 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 30 to 37
2019-02-23 14:21:04.252 [vent.ItemStateChangedEvent] - Dimmer01_Power changed from 30 to 37
2019-02-23 14:21:04.356 [vent.ItemStateChangedEvent] - Dimmer01_Watts changed from 30 to 37
2019-02-23 14:21:04.534 [vent.ItemStateChangedEvent] - Dimmer01_Watts1 changed from 30 to 37
2019-02-23 14:21:07.714 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 37 to 16.7
2019-02-23 14:21:19.122 [vent.ItemStateChangedEvent] - Dimmer01_Power changed from 37 to 16.7
2019-02-23 14:21:19.205 [vent.ItemStateChangedEvent] - Dimmer01_Watts changed from 37 to 16.7
2019-02-23 14:21:19.381 [vent.ItemStateChangedEvent] - Dimmer01_Watts1 changed from 37 to 16.7
2019-02-23 14:21:21.653 [vent.ItemStateChangedEvent] - Dimmer01_Power1 changed from 16.7 to 0.6
