I upgraded my OH 2.3 to 2.4, followed the official guide for the Z-Wave upgrade, deleted all the Things except for the Controller, all my Z-Wave devices started to populate the Inbox and everything looked great.
I could send commands to my devices, here is an example for a Flush 2 Relay when i change the state from OH
2019-01-01 10:38:04.800 [ome.event.ItemCommandEvent] - Item ‘ZWaveNode16ZMNHBAFlush2Relays_Switch1’ received command ON
2019-01-01 10:38:04.801 [nt.ItemStatePredictedEvent] - ZWaveNode16ZMNHBAFlush2Relays_Switch1 predicted to become ON
2019-01-01 10:38:04.803 [vent.ItemStateChangedEvent] - ZWaveNode16ZMNHBAFlush2Relays_Switch1
changed from OFF to ON
2019-01-01 10:38:07.123 [ome.event.ItemCommandEvent] - Item ‘ZWaveNode16ZMNHBAFlush2Relays_Switch2’ received command ON
2019-01-01 10:38:07.123 [nt.ItemStatePredictedEvent] - ZWaveNode16ZMNHBAFlush2Relays_Switch2
2019-01-01 10:38:07.123 [vent.ItemStateChangedEvent] - ZWaveNode16ZMNHBAFlush2Relays_Switch2 changed from OFF to ON
But the problem is if I change the state from the device with physical button then the state is not changed in OH and there is nothing in the events.log
This worked with Version 2.3, anyone have any ide where I should start looking? same error for all my relays.
Thanks for the reply.
I have checked the associations group and it seems strange, I use HABmin and it shows just an X if I add my Controller and save and then reload the page then it looks the same again, is this normal behavior in HABmin?
It looks like this for all my Z-Wave devices.
Thanks for the information, will the change to snapshot brake anything (that you are aware of)?
Is there a “upgrade” manual like when changing from 2.3 to 2.4?
