[SOLVED] Z-Wave, Unknown device, 010F:0303:1000:5.0, Fibaro Roller Shutter 3 (FGR-223)
Tags: #<Tag:0x00007f43425d14e8> #<Tag:0x00007f43425d1420> #<Tag:0x00007f43425d1358>
Hello everyone, I need help please for the same Problem.
My Hardware:
#1 Raspberry Pi 3 Modell B+ with openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img.xz
#2 ZMEEUZB1 (Z-WAVE Controller)
#3 Fibaro Roller Shutter 3 (FGR223)
My problem is that the RollerShutter stands there as an unknown device. I read everywhere that you can expand the database on cd-jackson.com. And the device is also listed there
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/983
But how do I get this device into my database of Openhab? :cold_sweat:
I also read a lot of XML files … but dont know what i want to do with the xml file?
Can someone please tell me step by step how I can extend the database… please :pray:
Thank You!
@Worik
Which OH version do you use?
EDIT: OK, I’ve overlooked it. It’s openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img.xz
It’s the latest version. I don’t know if device is in there… Sorry.
You can find the instructions here -:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-database-guide
However it’s unclear if this is really your problem since you say that you have the same problem and this problem should be resolved as this device is already in the database. Can you please state exactly what your problem is?
I had the similar problem last week with the fibaro rgbw module. It was not recognized…only as fibaro. On openHABian I pulled the latest release 2.4 and the database of z-wave got updated too…try to pull latest update (with openhabian-config) maybe this helps. And of course exclude and include again
The binding & database for 2.4 are NOT the latest for zwave. There is an upgrade script for the binding that can update it though.
Hi Chris,
this is my Problem:
but if you say that this device is already in the database, then I dont know anymore :weary: Why my openhab says all the time Unknown Device.
this is the XML File from srv/openhab2-userdata/zwave folder
network_c2e28f61__node_2.xml
Thanks for answer :slight_smile:
Strange - it looks like it should be ok - certainly the device is already in the database and has been there for quite a long time (as this issue suggests).
All I can really suggest is to enable TRACE level logging and see what that shows.
… TRACE level logging … Sounds complicated
Maybe the logflies from OpenHab will help
events.log
openhab.log
Not really. Look here starting at “When things don’t go as planned” but use TRACE instead of DEBUG.
Ok was not complicated :slight_smile: if that’s what Chris meant.
Thank you Bruce
Could not send the zwave.log im blocked for SPAM :flushed: That’s so frustrating… why Spam?
The zwave.log is on the same Adress like events.log and openhab.log wor-design_de/openhab/zwave.log hope you can find the issue.
System Blocked me … to fast answer maybe:
" Your post was flagged as spam : the community feels it is an advertisement, something that is overly promotional in nature instead of being useful or relevant to the topic as expected."
Sometimes the zwave log viewer can help you sort trough the logs.
https://www.cd-jackson.com/index.php/openhab/zwave-log-viewer
The log shows that the binding is not searching for your device. It looks like it doesn’t contain any new devices for the past few months, which indicates that maybe you’re running an older binding than you think?
I would suggest to check the versions using the console - ie logon to the console and list the running bindings to get their version.
Hello Chris,
here is a Screenshot of my List
openhab-cli console bundle:stop 206
openhab-cli console bundle:start 206
was worked to, after stop was the Binding off and after start was again on.
That explains the issue :slight_smile:
You are using quite an old version of the binding and it doesn’t contain this device. The version you have is 2.4 which was released in December last year if I remember correctly.
You will need to use one of the newer 2.5 versions - 2.5M2 should be ok I think.
@Worik
The easiest way to upgrade the binding is with Scott’s script.
I dont know why but it does not seem to work anything I touch :woozy_face::sleepy:
It does not work for me.
Maybe you know a another way? Or a better image Version for Raspberry Pi with the new Version fo the Z-Wave Binding?
Did you stop OpenHAB first?
It needs to be running for the script to detect & uninstall any existing biinding.
No it was running, but i have it now.
I Have now Install an a another SD-Card the Raspbian and after the openHAB 2.5.0.M2 Milestone Build
And now is the Z-Wave Binding Version - 2.5.0.M2 and under Supported Things is now the Fibaro 223 to :smiley:
And now works all fine !!!
Thank you very much for the very fast support !!! :slightly_smiling_face:
The Fact is that the https://github.com/openhab/openhabian/releases new version 05.08.2019 has old Zwave / Zway / Zigbee … Versions, all of them have 2.4
But for me ist the Problem now solved.
Thanks all for Help!
OpenHABian may default to the current stable release, which is currently 2.4. You can also choose testing or unstable releases though.
In fact I run OpenHABian with the latest testing release, 2.5M2.
Im new in all this OpenHab stuff. I will test the 2.5M2 now and watch, I have not deleted the other installation yet, maybe I have to go back to the 2.4 it will show up.
Now it only counts that it works, it has to be checked, if it can be linked and everything else before I buy some more.
