Sorry - I have not tested it, so if you know there is a limitation, then I assume it is correct.
The only Contacts I have linked to Channels are zwave. There are messages that âNode doesnât support get requestsâ, but at least for battery devices, this appears to work. Note, polling is started for all Channels, which may be a zwave binding specific âfeatureâ .
events.sendCommand("US_MasterBathroom_Contact", "REFRESH")
2019-05-31 18:44:25.566 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Command received zwave:device:07cb40a2:node69:alarm_entry --> REFRESH [RefreshType]
2019-05-31 18:44:25.566 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling intialised at 1800 seconds - start in 50 milliseconds.
2019-05-31 18:44:25.617 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling...
2019-05-31 18:44:25.617 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:alarm_entry
2019-05-31 18:44:25.617 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 69: Generating poll message for COMMAND_CLASS_ALARM, endpoint 0, alarm BURGLAR, event 2
2019-05-31 18:44:25.617 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 69: Node doesn't support get requests
2019-05-31 18:44:25.619 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:alarm_tamper
2019-05-31 18:44:25.620 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 69: Generating poll message for COMMAND_CLASS_ALARM, endpoint 0, alarm BURGLAR, event 3
2019-05-31 18:44:25.620 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 69: Node doesn't support get requests
2019-05-31 18:44:25.621 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:battery-level
2019-05-31 18:44:25.621 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveBatteryConverter] - NODE 69: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2019-05-31 18:44:25.622 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 69: SECURITY not supported
2019-05-31 18:44:25.622 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 69: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
events.sendCommand("US_MasterBathroom_Contact_Battery", "REFRESH")
2019-05-31 18:47:19.484 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Command received zwave:device:07cb40a2:node69:battery-level --> REFRESH [RefreshType]
2019-05-31 18:47:19.485 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling intialised at 1800 seconds - start in 50 milliseconds.
2019-05-31 18:47:19.535 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling...
2019-05-31 18:47:19.536 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:alarm_entry
2019-05-31 18:47:19.537 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 69: Generating poll message for COMMAND_CLASS_ALARM, endpoint 0, alarm BURGLAR, event 2
2019-05-31 18:47:19.537 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 69: Node doesn't support get requests
2019-05-31 18:47:19.538 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:alarm_tamper
2019-05-31 18:47:19.538 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 69: Generating poll message for COMMAND_CLASS_ALARM, endpoint 0, alarm BURGLAR, event 3
2019-05-31 18:47:19.539 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 69: Node doesn't support get requests
2019-05-31 18:47:19.539 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 69: Polling zwave:device:07cb40a2:node69:battery-level
2019-05-31 18:47:19.539 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveBatteryConverter] - NODE 69: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2019-05-31 18:47:19.540 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 69: SECURITY not supported
2019-05-31 18:47:19.540 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 69: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
Comment: likewise for Modbus, a large number of channels could be associated with one polled âblockâ of modbus registers, which are normally polled in one transfer.
Issuing a REFRESH to any one of those channels will cause a poll/update cycle for every register/channel in that block. (but not other blocks)
Can also confirm OH2.4 allows RERESH to Contact types (with the quotes kludge for now).
I do see what you are saying. On reflection, I think it needs a mention both in the general and specific bindings.
As Iâve just been reminded, what the total effect of a REFRESH does is very dependent on any target device, as âreadingâ a device/service could be limited to âreadingâ a whole bunch of related data from the device/service in one shot. Or grossly delayed, as in sleeping zwave. Depending on technology i.e. binding.
So, a generalised âintentâ for the commandâs purpose? And specific details per binding, where itâs non-obvious?
Thatâs what Iâm thinking. Itâs going to be a pain though to update the bindings docs, but the behavior is so specific to what the Binding does and the limitations of the technologies I see no other way. We can get the main page updated this weekend.
Does this mean that sending a refresh to a battery device locks up a thread until the device responds? In that case a warning about that might be appropriate. Your rules might lock up just like with sleep.
That means that it IS possible to send the REFRESH to a contact - just that in this case the device doesnât support it.
No - it doesnât mean that. It simply means that the device wonât really be refreshed until the device wakes - this is normal ZWave operation for battery devices.
I think many bindings maintain an internal queue of things-to-do while waiting for resources, e.g. modbus queues actions for several devices awaiting their turn on a shared bus. This adds no particular load to the system, itâs only a list.
item.sendCommand(REFRESH) never ever locks up a thread. Any more than myLight.sendCommand(ON) does. It just puts the command on OH event bus for anyone interested.
Note the implications of that - the results of REFRESH (or any other command) are not available immediately. It just kicks off a process. To get the results of any command you generally have to listen out for an update.
Thanks for the explanation! Really clear. Looking forward to playing with refresh.
Iâve known about it for ages, and it works for my main devices. But I donât think I use it anywhere in my setup. Itâs less useful than you think
Itâs most likely to be of use in some setup where you have to build your own keep-alive or long-delay poll setup, I think.
