Dear all,
I have a question regarding zigbee binding. I have a new IKEA tradfri rgb bulb which I want to include into my existing openHAB. I’m using OpenHAB 2.4.0 stable with the zigbee binding in combination with a telegesis UBS stick. Discovery of the bulb works very good out of the box. I can even control the bulb via a color item and turn the bulb on/off. Only dimmer and color change will work somehow suspect. I guess this is causes by the different format the IKEA tradfri bulb is working. I read some hints about that here in the forum.
But what I cannot figure out is how to use this bulb with the zigbee binding without a tradfri gateway? Did someone managed it? I guess with the gateway it should be no problem?
Does somebody has a hint for me how I can convert the HSBType color into the right format and send it to the bulb e.g. with a rule?
Thank you for your support in advance
BR, kutzi
