Bummer. Can you post your logs with and without haveged?
Would like to see the results of the new jar with vs without haveged
The 1 to 2 second delay is strange. the only change I made was to 1 line of code that should only impact the init time. Logs would hel phere as well
What chipset do you have? I think I have a NUC out in the garage, just curious if it is a .comparable CPU. Maybe I would be able to reproduce the problem
Thereās not enough entropy on my (hp micro)server or docker, causing the timeout and the stick not beeing initialized correctly.
To fix this, I just ran another container with haveged, which you might consider including directly in the openhab docker (not sure thatās possible without running privileged) :
docker run --privileged -d harbur/haveged
Once done, I got enough entropy and the stick got initialized (I had stopped the openhab docker before adding thehavged one) :
