I’m having big trouble with the ZWave binding since I upgraded to 2.5.0. I have a ZStick Gen5 and it seems to keep going offline, then online and a few time after offline again. It has worked very fine for years but since 2.5 I’m having this issue. When it’s online, and nodes get online also, every ZWave node works fine, but it keeps going offline a few minutes after. And it get online again without doing anything. Anyone had this behaviour ?
zwave_serial_zstick_3e2f2047_serial_sof changed from 78 to 79
2019-12-18 18:49:47.678 [WARN ] [WaveSerialHandler$ZWaveReceiveThread] - Exception during ZWave thread.
java.lang.IllegalStateException: Queue full
at java.util.AbstractQueue.add(AbstractQueue.java:98) ~[?:1.8.0_152]
at java.util.concurrent.ArrayBlockingQueue.add(ArrayBlockingQueue.java:312) ~[?:1.8.0_152]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.processReceiveMessage(ZWaveTransactionManager.java:417) ~[bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.incomingPacket(ZWaveController.java:1072) ~[bundleFile:?]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.incomingMessage(ZWaveControllerHandler.java:411) ~[bundleFile:?]
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.run(ZWaveSerialHandler.java:331) [bundleFile:?]
2019-12-18 18:50:19.999 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node21’ changed from ONLINE to UNINITIALIZED
2019-12-18 18:50:21.892 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node21’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-18 18:50:21.901 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node40’ changed from ONLINE to UNINITIALIZED
2019-12-18 18:50:25.647 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node40’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-18 18:50:25.795 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node34’ changed from ONLINE to UNINITIALIZED
019-12-18 19:04:45.329 [hingStatusInfoChangedEvent] - ‘zwave:device:3e2f2047:node59’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-18 19:04:46.332 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-12-18 19:04:47.040 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
