hello
i have problem adding zwave stick (EVERSPRING SA413-1) i’m using openhab 2.4 on raspberry pi 3, after connecting the stick to the USB port, it discover the stick, and i added it as thing, but it stuck on Initializing, tried to remove and re-added, and also uniinstall and reinstall the zwave binding, and also rebooting, nothing help, and it always stay on Initializing.
please help, thanks
the log
2018-11-27 13:35:23.257 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_can-zwave:serial_zstick:512:serial_can' has been added.
2018-11-27 13:35:23.326 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_oof-zwave:serial_zstick:512:serial_oof' has been added.
2018-11-27 13:35:23.360 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_ack-zwave:serial_zstick:512:serial_ack' has been added.
2018-11-27 13:35:23.478 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_cse-zwave:serial_zstick:512:serial_cse' has been added.
2018-11-27 13:35:23.718 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_nak-zwave:serial_zstick:512:serial_nak' has been added.
2018-11-27 13:35:23.831 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_512_serial_sof-zwave:serial_zstick:512:serial_sof' has been added.
2018-11-27 13:35:27.709 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:512' changed from UNINITIALIZED to INITIALIZING
2018-11-27 13:35:32.668 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'zwave:serial_zstick:512' takes more than 5000ms
update, i see this in the log now
2018-11-27 14:06:01.383 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port
'/dev/ttyACM0'
2018-11-27 14:06:01.392 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:512' changed from ONLINE
to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-11-27 14:06:03.401 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:512' changed from OFFLINE
(BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port {0} is
in use
