@chris
Are there any specific reason why I get an warning, after I have unlinked automatic created links to items from PaperUI, and then create the very same items (same ID) manually in a file afterwards?
I get the same warnings when I did the same to another z-wave device. And it tends to continue given me these warnings each time I reboot/restart OpenHab2.
Everything seem to work fine though, it´s just annoying seeing these warnings.
This is my logfile:
2018-07-18 22:12:23.064 [temChannelLinkRemovedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_BinarySensor => zwave:device:fef78fef:node11:sensor_door' has been removed.
2018-07-18 22:12:26.501 [temChannelLinkRemovedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_AlarmBurglar => zwave:device:fef78fef:node11:alarm_burglar' has been removed.
2018-07-18 22:12:30.589 [temChannelLinkRemovedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_BatteryLevel => zwave:device:fef78fef:node11:battery-level' has been removed.
2018-07-18 22:12:45.996 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'zwave.items'
2018-07-18 22:12:46.024 [WARN ] [ore.common.registry.AbstractRegistry] - ContactItem with key 'ZWaveNode11ZG8101GarageDoorTiltSensor_BinarySensor' already exists from provider ManagedItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
2018-07-18 22:12:46.028 [WARN ] [ore.common.registry.AbstractRegistry] - SwitchItem with key 'ZWaveNode11ZG8101GarageDoorTiltSensor_AlarmBurglar' already exists from provider ManagedItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
2018-07-18 22:12:46.031 [WARN ] [ore.common.registry.AbstractRegistry] - NumberItem with key 'ZWaveNode11ZG8101GarageDoorTiltSensor_BatteryLevel' already exists from provider ManagedItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
2018-07-18 22:12:46.042 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_BinarySensor-zwave:device:fef78fef:node11:sensor_door' has been added.
2018-07-18 22:12:46.050 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_AlarmBurglar-zwave:device:fef78fef:node11:alarm_burglar' has been added.
2018-07-18 22:12:46.058 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode11ZG8101GarageDoorTiltSensor_BatteryLevel-zwave:device:fef78fef:node11:battery-level' has been added.
