- Platform information:
- Hardware:
Raspberry Pi 3B, 64 GB micro SD - OS:
Raspbian GNU/Linux 9 (stretch)
Linux rpi3 4.14.70-v7+ #1144 SMP Tue Sep 18 17:34:46 BST 2018 armv7l - Java Runtime Environment:
zulu-embedded-8/azulsystems,now 8.25.0.76 armhf [installed] - openHAB version:
openHAB 2.4.0~20181012154014-1 (Build #1389)
- Hardware:
- Issue of the topic:
I have DSL rules in which I use item groups to monitor and control groups of lights comprising switch and dimmer items. I have determined that some item groups are not fully populated.
As an example of a group item that is not properly populated, I have the following item definitions:
// Groups
Group gOFLts "Office Lights" <office>
Group:Switch:OR(ON,OFF) gOFLtsOn "Office Lights [%s]" <office>
// Office
Dimmer OfficeFanLts "Office Fan Lights" (gOF,gOFLts,gOFLtsOn,gUpstairsLts,gLTs,G_PresenceSimulation) ["Lighting"]
Dimmer OfcTblLamp "Office Table Lamp" (gOF,gOFLts,gOFLtsOn,gUpstairsLts,gSSLts,gLTs,G_PresenceSimulation) ["Lighting"]
Dimmer TstLamp1 "Test Lamp 1" (gOF,gOFLts,gOFLtsOn,gUpstairsLts,gSSLts,gLTs,G_PresenceSimulation) ["Lighting"]
If I inspect the group membership of each of my items using the REST API, it shows only two members of group gOFLts:
"link": "http://rpi3.karnsfamily.org/rest/items/OfcTblLamp",
"state": "0",
"editable": false,
"type": "Dimmer",
"name": "OfcTblLamp",
"label": "Office Table Lamp",
"tags": [
"Lighting"
"groupNames": [
"gOF",
"gOFLts",
"gOFLtsOn",
"gUpstairsLts",
"gSSLts",
"gLTs",
"G_PresenceSimulation"
"link": "http://rpi3.karnsfamily.org/rest/items/TstLamp1",
"state": "0",
"editable": false,
"type": "Dimmer",
"name": "TstLamp1",
"label": "Test Lamp 1",
"tags": [
"Lighting"
"groupNames": [
"gOF",
"gOFLts",
"gOFLtsOn",
"gUpstairsLts",
"gSSLts",
"gLTs",
I don’t think my rules are a factor in this bug, but, for completeness of this problem report, my rules that act on gOFLts events are:
// Global Variables
val SEAR = "sun-elevation-azimuth.rules"
// Rules
rule "Manage Office *All Off* LED"
Item gOFLtsOn changed
val logID = SEAR + ".ofc-all-off-led"
val OnOffType newState = gOFLtsOn.state
logInfo(logID, "gOFLtsOn changed to {}", newState.toString())
try {
if (newState == ON) { // at least one Office light is ON
OF_KpLED_5.sendCommand(ON)
} else { // no Office lights are ON
OF_KpLED_5.sendCommand(OFF)
} catch (Throwable t) {
logError(logID, "'Manage Office *All Off* LED' rule: {}", t.toString())
rule "Handle Office Scene Button Press"
Item Desk_Pico_1 changed to ON
val logID = SEAR + ".ofc-scene-btn"
logInfo(logID, "Desk_Pico_1 button pressed")
try {
gOFLts.getAllMembers.forEach[ light |
logInfo(logID, "processing gOFLts member: {}", light.getName)
var osOnCmd = if (officeSceneSettings.containsKey(light.getName)) officeSceneSettings.get(light.getName) else DEFAULT_OS_ON_LEVEL
if (light instanceof SwitchItem) {
// light is either a SwitchItem or a DimmerItem as
// DimmerItem inherits from SwitchItem
if (light.getStateAs(OnOffType) == OFF) {
if (! (light instanceof DimmerItem)) {
osOnCmd = "ON"
logInfo(logID, "sendCommand({}, {})", light.getName, osOnCmd)
doSendCmd.apply(logID, light.getName, osOnCmd)
} else {
logInfo(logID, "light: {} is already ON", light.getName)
} else {
logError(logID, "item: {} is neither a Switch nor a Dimmer", light.getName)
logError(logID, "'Handle Office Scene Button Press' rule: {}", t.toString())
rule "Handle Office Lamp Button Press"
Item Desk_Pico_2 changed to ON
or Item Desk_Pico_3 changed to ON
val logID = SEAR + ".ofc-lamp-btn"
logInfo(logID, "Desk_Pico button 2 or 3 pressed")
val light = if (triggeringItem.name == "Desk_Pico_2" ) TstLamp1 else OfcTblLamp
val lightName = light.getName
var dp2Cmd = if (officeSceneSettings.containsKey(lightName)) officeSceneSettings.get(lightName) else DEFAULT_OS_ON_LEVEL
try {
if (light.getStateAs(OnOffType) == ON) {
dp2Cmd = "OFF"
logInfo(logID, "sendCommand({}, {})", lightName, dp2Cmd)
doSendCmd.apply(logID, lightName, dp2Cmd)
logError(logID, "'Handle Office Test Lamp Button Press' rule: {}", t.toString())
rule "Handle Office *All Off* Button Press"
Item OF_Keypad_5 changed to ON
or Item Desk_Pico_4 changed to ON
val logID = SEAR + ".ofc-all-off-btn"
val OnOffType ofcLtsState = gOFLtsOn.state
logInfo(logID, "OF_Keypad_5 button pressed, gOFLtsOn: {}", ofcLtsState.toString)
try {
if (ofcLtsState == ON) { // at least one Office light is ON
gOFLts.sendCommand(OFF)
logError(logID, "'Handle Office *All Off* Button Press' rule: {}", t.toString())
It is worth noting that when openhab2 starts, it goes through several “false” starts with various rules error reports that I attribute to a lack of any startup ordering, i.e., global variables (vals) that are declared and initialized in my rules are detected as having NULL values when the rules (prematurely) begin running.
Is this a known issue that is being debugged, or should I file an issue report?
[Update:]
I restarted OH2 for the third time since updating to release #1389 and the gOFLts group item is now correctly populated.
"link": "http://rpi3.karnsfamily.org/rest/items/OfficeFanLts",
"state": "96",
"editable": false,
"type": "Dimmer",
"name": "OfficeFanLts",
"label": "Office Fan Lights",
"tags": [
"Lighting"
"groupNames": [
"gOF",
"gOFLts",
"gOFLtsOn",
"gUpstairsLts",
"gLTs",
"state": "33",
"editable": false,
"type": "Dimmer",
"tags": [
"Lighting"
"groupNames": [
"gOF",
"gOFLts",
"gOFLtsOn",
"gUpstairsLts",
"gSSLts",
"gLTs",
"state": "33",
"editable": false,
"type": "Dimmer",
"name": "TstLamp1",
"tags": [
"Lighting"
"groupNames": [
"gOF",
"gOFLts",
"gOFLtsOn",
"gUpstairsLts",
"gSSLts",
"gLTs",
