Yes, I saw the comment in the code, too. How nice that they released the specs.
Thanks!
Thanks!
Interesting result. I think I might understand what’s happening. Let me know what you think.
Notice there’s only 1 SENSOR_MULTILEVEL_GET. Is that because the second one was a duplicate to the first one (since there’s now no sensor type in the message to make them unique)? I think these log entries might confirm that (notice the line about message already on the queue).
2016-09-14 19:33:27.714 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling...
2016-09-14 19:33:27.715 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:sensor_relhumidity
2016-09-14 19:33:27.715 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 7: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2016-09-14 19:33:27.716 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 7: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-09-14 19:33:27.717 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:sensor_temperature
2016-09-14 19:33:27.718 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 7: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2016-09-14 19:33:27.718 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 7: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-09-14 19:33:27.719 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:alarm_co2
2016-09-14 19:33:27.720 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:alarm_smoke
2016-09-14 19:33:27.721 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:battery-level
2016-09-14 19:33:27.721 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 7: Generating poll message for BATTERY endpoint 0
2016-09-14 19:33:27.721 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 7: Creating new message for application command BATTERY_GET
2016-09-14 19:33:27.722 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:sensor_temperature1
2016-09-14 19:33:27.722 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 7: Generating poll message for SENSOR_MULTILEVEL, endpoint 1
2016-09-14 19:33:27.722 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 7: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-09-14 19:33:27.722 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Encapsulating message, instance / endpoint 1
2016-09-14 19:33:27.723 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 7: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2016-09-14 19:33:27.723 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:154acc671d8:node7:sensor_relhumidity2
2016-09-14 19:33:27.723 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 7: Generating poll message for SENSOR_MULTILEVEL, endpoint 2
2016-09-14 19:33:27.724 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 7: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-09-14 19:33:27.724 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Encapsulating message, instance / endpoint 2
2016-09-14 19:33:27.724 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 7: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2016-09-14 19:33:27.725 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 7: Putting message SendData in wakeup queue.
2016-09-14 19:33:27.725 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 7: Message already on the wake-up queue. Removing original.
2016-09-14 19:33:27.726 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 7: Putting message SendData in wakeup queue.
The device seems to respond with two SENSOR_MULTILEVEL_REPORTs – one for temp and one for humidity. I guess we should’ve expected that? How will the new transaction code deal with that?
There’s now a BATTERY_REPORT, which is good!
The rest is confusing.
All in all, not perfect, but much better than before.
Here’s the full log in case you want to look at it.
https://drive.google.com/open?id=0Bwmcwu6ccTd_VE04STBBVFc2c0k
