Something is rounding my float values in sitemap
@fohdeesha Unfortunately I cannot reproduce the issue. Perhaps the issues are caused by something with your hardware/software/devices?
Please find the steps I used:
  1. Install 1.8.3 runtime openhab
  2. Install modbus 1.9.0 SNAPSHOT (2016-09-07)
  3. Configure openhab.cfg as follows
    modbus:tcp.slave1.connection=127.0.0.1:55502
    modbus:tcp.slave1.type=holding
    modbus:tcp.slave1.start=0
    modbus:tcp.slave1.length=2
    modbus:tcp.slave1.valuetype=uint16
    # another slave reading the same registers as float32
    modbus:tcp.slave1float.connection=127.0.0.1:55502
    modbus:tcp.slave1float.type=holding
    modbus:tcp.slave1float.start=0
    modbus:tcp.slave1float.length=2
    modbus:tcp.slave1float.valuetype=float32
  1. Configure default.items as follows
	Number Item0 "Item0 [%d]" (ALL) {modbus="slave1:0"}
	Number Item1 "Item1 [%d]" (ALL) {modbus="slave1:1"}
	Number Item0float "Item0 [%f]" (ALL) {modbus="slave1float:0"}
	Number Item1float "Item1 [%f]" (ALL) {modbus="slave1float:1"}
  1. Start Modbus/TCP server ./diagslave -m tcp -p 55502
  2. Start openhab ./start_debug.sh
    6.a. If necessary, install python 2.7.
    6.b. Download Pollmb from PollMB and PollWS
Startup log from openhab
20:49:11.422 [INFO ] [runtime.busevents             :26   ] - Item1 state updated to 0
20:49:11.423 [INFO ] [runtime.busevents             :26   ] - Item0 state updated to 291
20:49:11.476 [INFO ] [runtime.busevents             :26   ] - Item0float state updated to 0.000000000000000000000000000000000000029938371747505134968578758682379069606944138399039104063426020019278439576737582683563232421875
Test A: Single register, 291 (uint16) or 0x0123 (hex)
pollmb/pollmb.py -h 127.0.0.1 -p 55502 -t 2 -f 16 -a 0 -q 1 -d 0123
20:49:49.529 [INFO ] [runtime.busevents             :26   ] - Item1 state updated to 0
20:49:49.529 [INFO ] [runtime.busevents             :26   ] - Item0 state updated to 291
Test B: Single register, 3000 (uint16) or 0x0BB8 (hex)
pollmb/pollmb.py -h 127.0.0.1 -p 55502 -t 2 -f 16 -a 0 -q 1 -d 0BB8
20:33:38.075 [INFO ] [runtime.busevents :26 ] - Item0 state updated to 3000
20:51:25.132 [INFO ] [runtime.busevents             :26   ] - Item0float state updated to 0.000000000000000000000000000000070874221953450279392459988287125325322202140654326285584829747676849365234375
20:51:25.192 [INFO ] [runtime.busevents             :26   ] - Item0 state updated to 3000
Test B: Two registers, 0x42C8999A (hex) = 100.3 (float)
pollmb/pollmb.py -h 127.0.0.1 -p 55502 -t 2 -f 16 -a 0 -q 2 -d 42C8999A
20:52:03.522 [INFO ] [runtime.busevents             :26   ] - Item0float state updated to 100.3000030517578125
20:52:03.582 [INFO ] [runtime.busevents             :26   ] - Item1 state updated to 39322
20:52:03.582 [INFO ] [runtime.busevents             :26   ] - Item0 state updated to 17096
Please note that 0x42C8999A matches the uint16 items as well (you can check these online)
0x999A (hex)= 39322 (uint16)
0x42C8 (hex) = 17096 (uint16)
In all the above cases the values remained constant after the write.
Extra: Documentation for pollmb here
