Hi all,
I am not sure what has changed, I do not think its necessarily Openhab.
I had the rule below working successfully for a good 6 months and I noticed today it was not functioning and instead throwing an error and not liking the Echo1.state(int) see exact error below.
In order to troubleshoot I stuck in a logInfo message that spits out the contents of Echo1.state which is 1.0 and then after getting this I coded the new create timer line to specify the value of 1 which permits the rule to run correctly.
I have probably a hundred of these lines with me using a variable that is set through the sitemap to a time delay throughout my rule base. So my question
What has changed and what must I do now to programically adapt?
ORIGINAL LINE
//createTimer(now.plusSeconds(Echo1.state as Number).intValue) [ | {
ERROR THROWN
2020-05-23 09:18:06.252 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Alexa Check office status': An error occurred during the script execution: Could not invoke method: org.joda.time.DateTime.plusSeconds(int) on instance: 2020-05-23T09:18:06.252+12:00
TEST WORKAROUND
rule "Alexa Check office status"
Member of EchoCmds changed to "office status"
val sourceRoom = triggeringItem.name.split("_").get(0)
val _TTS = sourceRoom+"_Echo_TTS"
logInfo("Test","Echo1 State:"+Echo1.state)
createTimer(now.plusSeconds(1)) [ | {
if (HO_Temp.state == NULL) {
_TTS.sendCommand("The office state is unknown."+" The temperature control is "+HO_Temp_Auto.state)
logInfo("HO_Temp_Status","Message : office temperature status is unknown.")
} else {
_TTS.sendCommand("The temperature state is considered "+HO_Temp_State.state+", and the temperature control is "+HO_Temp_Auto.state)
Paul
