I’m having some trouble with rules. All works as expected, but sometimes commands in Rules are not executed. This happens every 2-3 days. The same thing happens with other rules, so this seems a generic problem on my server.
There are no errors, no high loads, no other problems as I can see.
Can someone please help me with this?
Example rule
rule “Wenn_EG_Empfang_Scharf”
Item EG_Empfang_Scharf changed to ON
logInfo(“FILE”, “Start EG Scharf: Praesenz AUS, alle Lichter im EG ausschalten”)
EG01_LED_Stripe.sendCommand(“1200,76,90”)
logInfo(“FILE”, “Stop EG Scharf: Praesenz AUS, alle Lichter im EG ausschalten”)
The Logfiles show that both logInfos worked, but the Command between is not allways executed. Most of the time sendCommand is executed, but sometimes not.
2020-09-18 02:42:25.131 [INFO ] [.eclipse.smarthome.model.script.FILE] - Start EG Scharf: Praesenz AUS, alle Lichter im DG ausschalten
2020-09-18 02:42:25.134 [INFO ] [.eclipse.smarthome.model.script.FILE] - Stop EG Scharf: Praesenz AUS, alle Lichter im DG ausschalten
- Platform information:
- Hardware: Proxmox VM/ 8 GB RAM
- OS: Ubuntu 20.04.1 LTS
- Java Runtime Environment: Zulu 8.46.0.19-CA-linux32
- openHAB version: 2.5.7 Release Build
