this is just to inform you: the SSL certificate of tahomalink.com expired this night. Therefore the Somfy Tahoma binding is not working any longer.
Regards
Reinhold
Regards
Reinhold
Hello guys,
this binding uses the default HttpClient which requires a valid certificate by default.
So the right solution is to wait for Somfy to update their cert for the tahomalink.com domain.
But meanwhile you can try this workaround…
https://www.dropbox.com/s/u1lcza8wnyclr24/org.openhab.binding.somfytahoma-3.3.0-SNAPSHOT.jar?dl=1
Please let me know if it works (uninstall the bundled binding and copy this one to the addons directory)
Regards
Ondrej
