Hi guys,
I’ve intergrated the most of my somfy io devices with the somfy binding. Almost everything works fine. The only thing is that the orientation of the blinds is inverted.
According the binding description i defined them as Dimmer items to be able to use them with Alexa. Two items each blind. One for position and one for orientation of the blind.
Unfortunatly the orientation is inverted:
0% -> fully closed
100%-> fully opened
Position command works correctly. The same way like my rollershuters:
0%-> fully opene
100%-> fully closed
Is there a work around to reverse the orientation the right way? I thought about using proxy items. Any other ideas from your side?
