Using OpenHAB v2.0
I have a ZRTSI (Z-Wave to Somfy RTS Interface) to control my cellular shades.
The ZRTSI exposes a Z-Wave main node and 16 Z-Wave Control Channel ‘virtual’ nodes.
I have it working correctly with control channels 1 to 9 and each of the Z-Wave ‘devices’ show in Paper UI as ‘ZRTSI-VNODE Z-Wave to RTS Interface Virtual Node’
However the remaining 7 channels (10-16) are detected as ‘Unknown Device’.
I believe I have tracked down the source of the problem to the device definition. I sent the email below to the binding developer and owner of the website but have received no response:
Regarding this page: http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/370
There is a bug in the listed References (Type:Id) field.
This device has 16 virtual nodes with deviceids (decimal) from 21505 to 21520. This translates to (HEX) 5401 to 5410.
It looks as if decimal counting was applied to the device ids, …5409, 5410, 5411 … etc. This should be in HEX.
Which means channels 10,11,12,13,14,15 are out of range and channel 16 appears as channel 10.
Field ‘References (Type:Id)’ should contain:
5A52:5401,5A52:5402,5A52:5403,5A52:5404,5A52:5405,5A52:5406,5A52:5407,5A52:5408,5A52:5409,5A52:540A,5A52:540B,5A52:540C,5A52:540D,5A52:540E,5A52:540F,5A52:5410
I am unable to get OpenHAB to compile in Eclipse and the online instructions appear out of date but this is a separate issue… so I can’t fix it myself even if I knew how.
Can anyone guide me on how to fix the problem locally (possibly through config files?) or if the code could be patched and an update released?
Any help is greatly appreciated so that I can get these remaining channels working.
