Somfytahoma binding and ClosureState
I installed the somfytahoma binding for connection with my connectivity kit. This is working fine with 3 commands DOWN, UP ans STOP. Looking at the GUI at the things from Somfy RS100 Solar IO I see a property called ClosureState. This gives the % of the screen is closed. How can I get this item available?
Create an Item and link it to that Channel on the Thing.
You can click on the Channel and click “Add link to item…”. From there you can select an existing Item or create a new Item.
If you are using the semantic model and have already creat an Equipment for this Thing, you can choose “add points to model” and select the Channel and create the Item from there.
If I remember well I did this in the past but then the items where shown as unlinked and that is not the case. The properties are shown as core. Maybe that is the reason
image. I expect that this is not available as channel in the binding. Maybe something for Ondrej Pecta,
