Hi Gary, i tried that, but without any change in effect.
Until now i was testing this on a test Pi, but i have also tried it now on my production Pi (changed the IP in Tasmota mqtt, and changed the broker-id in the items and rules files).
However the behaviour is exactly the same… I am able to switch the B1 on/off, and i am able to set the color of the color leds with the color picker. But the sliders do not appear as sliders in my sitemap…
But with the Tasmota web-if everything is working OK.
I get the same error messages from mqtt as with the other platform:
2018-07-30 12:17:25.486 [ERROR] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
org.openhab.core.transform.TransformationException: Invalid path '$.Color' in '{"POWER":"ON"}'
mqtt messages:
openhab@openhab:~ $ mosquitto_sub -v -h 192.168.178.54 -p 1883 -t '+/Sonoff_1B1/#'
tele/Sonoff_1B1/LWT Online
cmnd/Sonoff_1B1/DIMMER INCREASE
cmnd/Sonoff_1B1/COLOR ff1a160000
cmnd/Sonoff_1B1/POWER ON
stat/Sonoff_1B1/POWER OFF
stat/Sonoff_1B1/RESULT {"Dimmer":49}
cmnd/Sonoff_1B1/DIMMER DECREASE
cmnd/Sonoff_1B1/COLOR 0000002953
stat/Sonoff_1B1/RESULT {"POWER":"ON","Dimmer":32,"Color":"0000002851","HSBColor":"0,0,0","Channel":[0,0,0,16,32],"CT":500}
cmnd/Sonoff_1B1/POWER OFF
stat/Sonoff_1B1/RESULT {"POWER":"OFF"}
stat/Sonoff_1B1/RESULT {"POWER":"ON"}
stat/Sonoff_1B1/POWER ON
tele/Sonoff_1B1/STATE {"Time":"2018-07-30T11:22:54","Uptime":"0T01:25:17","Vcc":3.634,"POWER":"ON","Dimmer":32,"Color":"0000002851","HSBColor":"0,0,0","Channel":[0,0,0,16,32],"CT":500,"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"OFF","Wifi":{"AP":1,"SSId":"NoAccess-3","RSSI":42,"APMac":"5C:49:79:51:78:1E"}}
cmnd/Sonoff_1B1/COLOR 0204022851
stat/Sonoff_1B1/RESULT {"POWER":"ON","Dimmer":31,"Color":"010301264F","HSBColor":"120,67,1","Channel":[0,1,0,15,31],"CT":500}
cmnd/Sonoff_1B1/COLOR 7dcc6d264F
stat/Sonoff_1B1/RESULT {"POWER":"ON","Dimmer":80,"Color":"7CCC6C254E","HSBColor":"110,47,80","Channel":[49,80,42,15,31],"CT":287}
cmnd/Sonoff_1B1/COLOR 89df78254E
stat/Sonoff_1B1/RESULT {"POWER":"ON","Dimmer":87,"Color":"87DC77244D","HSBColor":"110,46,86","Channel":[53,86,47,14,30],"CT":275}
