Hi there,
I have just set up two Sonoff DUAL, and I have the problem that when I set up as a Switch (ON OFF), on the BASIC page, if I turn on, after 5 seconds, change to OFF automatically …
This is turning me crazy.
Thank you in advances.
Events log:
2018-04-01 22:26:59.855 [ome.event.ItemCommandEvent] - Item ‘SonoffDUAL02_1_Color’ received command ON
2018-04-01 22:26:59.866 [vent.ItemStateChangedEvent] - SonoffDUAL02_1_Color changed from OFF to ON
2018-04-01 22:27:01.509 [ome.event.ItemCommandEvent] - Item ‘SonoffDUAL02_2_Color’ received command ON
2018-04-01 22:27:01.520 [vent.ItemStateChangedEvent] - SonoffDUAL02_2_Color changed from OFF to ON
2018-04-01 22:27:03.611 [vent.ItemStateChangedEvent] - SonoffDUAL02_1_Color changed from ON to OFF
2018-04-01 22:27:03.627 [vent.ItemStateChangedEvent] - SonoffDUAL02_2_Color changed from ON to OFF
Such could be a SWITCHMODE other then 0 (enter: “SWITCHMODE” into the console of the sonoff), or you have the item switch automatically by use of the expiry binding, or a rule?
Other then that???
I have, SWITCHMODE 0.
I do not have any rule.
About the expiry binding, I do not understand what you mean, sorry :S…
I have a HUW bridge (Amazon ECO), and then the inbox detect the sonoff dual R2, I link to a Switch, and everything works fine, but the status change after 5 seconds aprox. If I re-setup veverything, maybe happens the opposite, when I turn it OFF, then change to ON automatically. This is crazy I do not what to do.
I use, last version of openhab, sonoff bassic work like a charm.
I have reflashed a few times the sonoff DUAL R2. Happen with more DUAL R2.
I am not working with MQTT yet, I do not know how doe it work actually? Do I need to install more app in addition to Openhab2 to run with MQTT?
I need to read about MQTT, before starting to work with MQTT
I have though to make a rule, to visualize the proper Status, but I do not know how to get the “real” state of the relay, and according it, visualize the ON or OFF status. is it possible? (Then I will see how to setup eveything with MQTT.
Yes, you run them both on your raspi. When I installed it via OPenhabian, then the MQTT broker was installed automatically on the raspberry pi, during the initial installation.
I have Raspbian and Openhab2 already installed in the Raspberry Pi. All documentation I read, tells me that I have to burn the SD card to install openhabian. Is there any procedure to install openhabian from terminal?
Openhabian is meant to be a complete image, hence IMHO the answer is No.
However, it is the fastest and most promising way to install OH and all needed dependecies!
