Hello there,
I bought a sonoff POW R2 with Tasmota Flashed from ebay and try to integrate it into my openhab2 running on my Raspi to monitore the power production of my Solar Panels.
Sonoff is running and available in my network.
The configuration looks like this:
I intalled the MQTT Binding 2.4 in paper UI of openhab.
I made a bridge like this in the things:
Bridge mqtt:broker:MqttBroker "MqttBroker" [ host="localhost", port=1883, secure=false /* username="", password="", clientID="openHAB2"/*/ ]
Thing topic sonoffpow "Sonoff POW" @ "Photovoltaik" {
Channels:
Type string : reachable "Reachable" [ stateTopic="tele/sonoff-pow/LWT" ]
Type switch : power "Power" [ stateTopic="stat/sonoff-pow/POWER", commandTopic="cmnd/sonoff-pow/POWER" ]
Type number : powerload "Power load" [ stateTopic="tele/sonoff-pow/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Power"]
Type number : voltage "Line voltage" [ stateTopic="tele/sonoff-pow/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Voltage"]
Type number : current "Line current" [ stateTopic="tele/sonoff-pow/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Current"]
Type number : total "Total energy today" [ stateTopic="tele/sonoff-pow/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Today"]
Type number : totalyest "Total energy yesterday" [ stateTopic="tele/sonoff-pow/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Yesterday"]
Type number : rssi "WiFi Signal Strength" [ stateTopic="tele/sonoff-pow/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI"]
The following items are defined:
//-> Sonoff
Group FF_Sonoff_POW "Sonoff POW" <sonoff_pow> (Sonoff_POW)
String FF_Sonoff_POW_Reachable "Reachable: [%s]" <contactable> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:reachable" }
Switch FF_Sonoff_POW_Power "Power []" <sonoff_pow> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:power" }
Number FF_Sonoff_POW_Load "Power load [%.1f W]" <voltage> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:powerload" }
Number FF_Sonoff_POW_Voltage "Line voltage [%.1f V]" <voltage> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:voltage" }
Number FF_Sonoff_POW_Current "Line current [%.3f A]" <current> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:current" }
Number FF_Sonoff_POW_Today "Total energy today [%.3f kWh]" <total_energy> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:total" }
Number FF_Sonoff_POW_Yesterday "Total energy yesterday [%.3f kWh]" <total_energy> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:totalyest" }
Number FF_Sonoff_POW_RSSI "WiFi Signal Strength [%d %%]" <wifi> (FF_Sonoff_POW) { channel="mqtt:topic:MqttBroker:sonoffpow:rssi" }
But I can not get any value in the paper UI or switch it on or off
2019-06-28 00:50:41.529 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid paho91504783931 and file store '/var/lib/openhab2/mqtt/localhost'
2019-06-28 00:50:41.596 [WARN ] [ternal.TopicSubscribeMultiConnection] - Failed to MQTT subscribe for mqtt:broker:MqttBroker on topic homeassistant/#
2019-06-28 00:50:41.609 [INFO ] [ansport.mqtt.internal.ClientCallback] - MQTT connection to 'localhost' was lost
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:220) [227:org.eclipse.paho.client.mqttv3:1.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.util.ConcurrentModificationException
at java.util.HashMap.forEach(HashMap.java:1292) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ConnectionCallback.onSuccess(MqttBrokerConnection.java:134) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.ConnectActionListener.onSuccess(ConnectActionListener.java:99) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.fireActionEvent(CommsCallback.java:321) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleActionComplete(CommsCallback.java:260) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:190) ~[?:?]
... 7 more
Bridge mqtt:broker:MqttBroker "MqttBroker" [ host="localhost", port=1883, secure=false /* username="", password=""/*/, clientID="openhab2" ]
Channels:
But still the error in the log:
2019-06-28 01:05:06.012 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'localhost'. Next attempt in 10000ms
2019-06-28 01:05:06.023 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid openhab2 and file store '/var/lib/openhab2/mqtt/localhost'
2019-06-28 01:05:07.008 [INFO ] [ansport.mqtt.internal.ClientCallback] - MQTT connection to 'localhost' was lost
org.eclipse.paho.client.mqttv3.MqttException: Verbindung wurde getrennt
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:181) [227:org.eclipse.paho.client.mqttv3:1.2.0]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133) ~[?:?]
... 7 more
I installed Mosquitto Mttq Broker in the openhab config optional components. I did not set a password there but it sais, the username is “openhabian”.
So I used the username openhabian in the *.things file of the bridge.
It loooks like this now:
Bridge mqtt:broker:mosquitto "Mosquitto" [ host="192.168.178.42", port=1883, secure=false, username="openhabian", password="", clientID="openhab2" ]
Channels:
The Items are as follows:
//-> Sonoff
String FF_Sonoff_POW_Reachable "Reachable: [%s]" <contactable> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:reachable" }
Switch FF_Sonoff_POW_Power "Power []" <sonoff_pow> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:power" }
Number FF_Sonoff_POW_Load "Power load [%.1f W]" <voltage> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:powerload" }
Number FF_Sonoff_POW_Voltage "Line voltage [%.1f V]" <voltage> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:voltage" }
Number FF_Sonoff_POW_Current "Line current [%.3f A]" <current> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:current" }
Number FF_Sonoff_POW_Today "Total energy today [%.3f kWh]" <total_energy> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:total" }
Number FF_Sonoff_POW_Yesterday "Total energy yesterday [%.3f kWh]" <total_energy> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:totalyest" }
Number FF_Sonoff_POW_RSSI "WiFi Signal Strength [%d %%]" <wifi> (FF_Sonoff_POW) { channel="mqtt:topic:mosquitto:sonoffpow:rssi" }
Don’t you get any log-entries when switching the sonoff directly on the device?
Additionally, what does the console of the sonoff Show when trying to switch from openHAB?
According the last two lines on the console your sonoff got switched to POWER ON via MQTT, iow by openHAB. Doesn’t the openHAB power switch reflect this power state of the device?
The log lines from openHAB are from a timeframe 08:08 ff, on the sonoff console they are from an hour earlier???
I swiched to “on” directly in sonoff using “toggle” button.
Swiching in openhab paper ui has no effect - and no error log:
Events log:
2019-06-28 08:36:15.827 [ome.event.ItemCommandEvent] - Item 'FF_Sonoff_POW_Power' received command ON
2019-06-28 08:36:15.837 [nt.ItemStatePredictedEvent] - FF_Sonoff_POW_Power predicted to become ON
2019-06-28 08:36:15.843 [vent.ItemStateChangedEvent] - FF_Sonoff_POW_Power changed from OFF to ON
openhab log:
2019-06-28 08:30:32.069 [INFO ] [.smarthome.model.script.system.rules] - Uptime updated to 19 Min.
2019-06-28 08:35:32.073 [INFO ] [.smarthome.model.script.system.rules] - Uptime updated to 29 Min.
2019-06-28 08:38:20.312 [INFO ] [.eclipse.smarthome.model.script.Test] - Running Window openNEW Rule: EG_Vi_hkpump == OFF
OK. That sounds correct (I didn’t install Mosquitto that way).
Do you have an external MQTT Viewer like MQTTfx in order to check if messages are are running at all?
No, I don’t have it yet. I will install it as soon as I am back at home.
What is strange for me - in Sonoff overview it sais “MQTT Client DEV_15C2BB”.
The Client ID in *.Things is “openhab2”.
But when I change it to “openhab2” in Sonoff, the binding goes offline.
I think Ihave spotted the real problem: You did setup the mqtt topic as “sonoff” or “sonoffpow” on the sonoff device. The topics you subscribed in openHAB for are using “sonoff-pow”!
