Hello, I’ve been working to make a SONOFF RF Bridge turn on or off when a 433Mhz RC button is pressed.
I’m using the MQTT v2 from David Graeff and I tried to adapt all the rules to the new standard. I’m running the following rule:
rule "Button pressed"
when Item Sonoff_RF_Received_Data received update
Thread::sleep(100)
if (Sonoff_RF_Received_Data == NULL) {
logInfo("RfBridge.rules", "Item is null, cancelling...")
return; // do nothing if NULL
var rfData = Sonoff_RF_Received_RfKey.state.toString
logInfo("RfBridge.rules", "Received IT codes: " + rfData)
switch (rfData) {
case "1" :
logInfo("regra SONOFF BRIDGE", "-> Sala_estar_light liga")
val Actions = getActions ("mqtt", "mqtt:broker:Mosquitto")
Actions.publishMQTT("cmnd/sonoff-sala/power1", "ON")
case "5" :
logInfo("regra SONOFF BRIDGE", "-> Sala_estar_light desliga")
Actions.publishMQTT("cmnd/sonoff-sala/power1", "OFF")
when I press the button RFKey 1, looking at the logs, I can see that the MQTT message is sent and the light turns ON. However, when I press 5, I see at the log that the light will switch off but nothing happens.
Logs file:
2020-04-14 15:13:36.919 [INFO ] [marthome.model.script.RfBridge.rules] - Received IT codes: 1
2020-04-14 15:13:36.922 [INFO ] [ome.model.script.regra SONOFF BRIDGE] - -> Sala_estar_light liga
2020-04-14 15:13:40.744 [vent.ItemStateChangedEvent] - Sonoff_RF_Received_Sync changed from 7340 to 7330
2020-04-14 15:13:40.761 [vent.ItemStateChangedEvent] - Sonoff_RF_Received_RfKey changed from 1 to 5
2020-04-14 15:13:40.766 [vent.ItemStateChangedEvent] - Sonoff_RF_Received_Data changed from B46388 to B4638C
2020-04-14 15:13:40.879 [INFO ] [marthome.model.script.RfBridge.rules] - Received IT codes: 5
2020-04-14 15:13:40.887 [INFO ] [ome.model.script.regra SONOFF BRIDGE] - -> Sala_estar_light desliga
Any help will be appreciated!
Paulo
