I’m currently trying to add automation to my cinema room. I have a projector screen that is controller by a remote. The remote tells me it is 433.92 mhz. This one:
Probably, but it can be some work. If the codes arent supported from the native decoding RF Chip in the bridge you have to flash 2 custom firmwares on the RF Bridge. Tasmota for the ESP and for the RF Chip EFM Portisch firmware. After that code sniffing is possible and after converting the sniffed code you can send it…
All you need can you find here: https://github.com/arendst/Sonoff-Tasmota
