basically topic, I need something which will be able to utilize mqtt (tasmota ideally) or whatever programming language in desperate situation which supports learning of 433 rolling code.
I would like to control my gate, sadly sonoff does support only fixed codes ;(
or smthing which will be able to learn 40mhz fixed code freq which i can add to my gate control as well if needed.
unfortunately no, I’m now in process of understanding which circuits actually triggers relays on the board itself and my plan is to add esp8266 into the process directly.
seems like nobody really doing rolling code bridges
