Running Openha2 latest on PI3b.
I do have now (thanks Vincent) also a sonoff tasmota basic up an running. I see the state of the sonoff reflected in my basic ui - all OK so far.
Now my next adventure where I need your help. I would like to use the state “ON” from the sonoff as an alarm trigger. I do have a PIR connected to the sonoff what switchs the sonoff “ON” for a second and OFF again. After 9 seconds the PIR can fire again for a second and so on.
Now I would like to use this activation of the sonoff as a “counter” and when activated 3 times in a minute I would like to switch an already existent Z-WAVE+ plus switch which is activating a sirene.
Now I would need someone who can help me with to build a rule cause I never will get it allone
My sonoff item is called Sonoff1
Switch Sonoff1 {mqtt=">[broker:cmnd/sonoff1/POWER:command:*:default],<[broker:stat/sonoff1/POWER:state:default" }
and the Z-Wave+ item is called
zwave_device_296beed3_node4_switch_binary
So I have no idea how to transfer the sonoff state into a counter and when this counter is reaching 3 - switching my zwave+ switch for lets say 3 minutes.
Hope someone can support me with this
