When posting code, please use the code tags ( selectable by the icon</>)
As posted earlier, use the conversion “as Number”!
rule “Heat Transfer Fan on/off”
Item Sonoff_TH16_3_temperature changed
if((Sonoff_TH16_3_temperature.state as Number)> 20){
SoPow1_SW_ON_OFF.sendCommand(ON)
When testing own rules, using the “logInfo” lines you can check wether the rule is run over that line or exited before and you can display the actual value of a variable, value or item.state.
Hi! I have setting a generic module with 2 switch and one relay.
Switch1 on relay 1 and switch 2 indipendent. She work, but when I turn off the server mqtt, relay 2 work on relay 1. Can you Help me!
Yes I have the mqtt server disabled. but the relay and the buttons are on the same esp. the ESP being a microcontroller should be able to act even without Mqtt server. I imagine that mqtt is indispensable when I have to reach a relay or a button on another esp.
So it has neither to do with Sonoff nor with creating a rule. You are better off with a new thread which should have nodeMCU and Tasmota in the topic. That way it may catch the eye of a person with knowledge in those topics.
