Hi Newbie question
Raspberry pi 4
Openhabian
Configuration / Things / Channels
MQTT state topic is that?
stat/“topic”/POWER
MQTT Command Topic
cmnd/“topic”/POWER
topic is the sonoff device topic
Is that correct?
Hi Newbie question
Raspberry pi 4
Openhabian
stat/“topic”/POWER
MQTT Command Topic
cmnd/“topic”/POWER
Is that correct?
That depends on your MQTT setup of the Tasmota device.
Assuming you have set something for the MQTT Topic ( for example MyTopic
) and have left the full topic as it is, your statetopic for MQTT setup of openHAB would be:
stat/MyTopic/POWER
at first glance it looks good. But without any further information it is hard to tell. Use MQTT.fx and check what the Tasmote device is sending
Many thanks just wanted to make sure
