HI all,
Upfront I apologise if this has totally been covered by someone, I have read so much on this topic but seem to not find a solution.
In short, I have flashed a Sonoff Touch [(https://sonoff.itead.cc/en/products/residential/sonoff-t1)], with my own ESP8266 code. I did NOT use Tasmota. The Touch is connected to the wifi, and I can even publish MQTT topics to it, and it responds. (I can make all three the relays). However, the physical buttons on the touch does not work. So my challenge is not so much OH, but in the ESP8266 code.
When I say my own code, I mean code I have used on other ESP8266’s and ESP32’s I have around the house. Mostly sprinklers, lights via relays and such. The Sonoff touch is the first time I have had to publish MQTT topic from the “thing”.
I have the following setup.
OpenHAB 2.4
MQTT v1 (but have the v2 addon for all my other ESP’s to work)
Here is a copy of my items entries:
Blockquote
Switch kitchenswitch1 “Kitchen Switch1” (grp_kitchen, grp_houselights) [ “Lighting” ] {mqtt=">[broker:openhab/in/kitchen:command:ON:switch1ON],>[broker:openhab/in/kitchen:command:OFF:switch1OFF]"}
Switch kitchenswitch2 “Kitchen Switch2” (grp_kitchen, grp_houselights) [ “Lighting” ] {mqtt=">[broker:openhab/in/kitchen:command:ON:switch2ON],>[broker:openhab/in/kitchen:command:OFF:switch2OFF]"}
Switch kitchenswitch3 “Kitchen Switch3” (grp_kitchen, grp_houselights) [ “Lighting” ] {mqtt=">[broker:openhab/in/kitchen:command:ON:switch3ON],>[broker:openhab/in/kitchen:command:OFF:switch3OFF]"}
Here is my ESP8266 code.
Blockquote
#include <ESP8266WiFi.h>
#include <MQTTClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
/* WIFI Settings /
// Name of wifi network
const char ssid = “xxxxxx”;
// Password to wifi network
const char* password = "xxxxxx";
/* Web Updater Settings */
// Host Name of Device
const char* host = "KitchenSonoffSwitch";
// Path to access firmware update page (Not Neccessary to change)
const char* update_path = "/firmware";
// Username to access the web update page
const char* update_username = "xxxx";
// Password to access the web update page
const char* update_password = "xxxx";
/* MQTT Settings */
// Topic which listens for commands
const char* subscribeTopic = "openhab/in/kitchen";
//MQTT Server IP Address
const char* server = "192.168.0.18";
//Unique device ID
const char* mqttDeviceID = "KitchenSonoffSwitch";
int channel1 = 12; // for the relays, these work!
int channel2 = 5; // for the relays, these work!
int channel3 = 4; // for the relays, these work!
int button1 = 0; // this is for the SONOFF button I think
int button2 = 9; // this is for the SONOFF button I think
int button3 = 10; // this is for the SONOFF button I think
int buttonState1 = digitalRead(button1);
int buttonState2 = digitalRead(button2);
int buttonState3 = digitalRead(button3);
//webserver
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
//MQTT
WiFiClient net;
MQTTClient client;
unsigned long lastMillis = 0;
//Connect to WiFI and MQTT
void connect();
//Setup pins, wifi, webserver and MQTT
void setup() {
Serial.begin(115200);
delay(10);
// set pin modes for the relays, these work!
pinMode(channel1, OUTPUT);
digitalWrite(channel1, LOW);
pinMode(channel2, OUTPUT);
digitalWrite(channel2, LOW);
pinMode(channel3, OUTPUT);
digitalWrite(channel3, LOW);
// set button modes // this is for the SONOFF buttons
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
WiFi.mode(WIFI_STA);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
client.begin(server, net);
// client.onMessage(messageReceived);
connect();
MDNS.begin(host);
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
MDNS.addService("http", "tcp", 80);
//Connect to wifi and MQTT
void connect()
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println(WiFi.localIP());
while (!client.connect(mqttDeviceID))
delay(500);
client.subscribe(subscribeTopic);
void loop()
// MQTT Loop
client.loop();
delay(10);
// Make sure device is connected
if(!client.connected())
connect();
httpServer.handleClient();
// willie button code starts. My effort to get the physical buttons to work
if(buttonState1 == HIGH)
client.publish("openhab/in/kitchen", "switch1ON");
digitalWrite(channel1, HIGH);
delay(250);
else if(buttonState1 = LOW)
client.publish("openhab/in/kitchen", "switch1OFF");
// digitalWrite(channel1, LOW);
delay(250);
else if(buttonState2 == HIGH)
client.publish("openhab/in/kitchen", "switch2ON");
digitalWrite(channel2, HIGH);
delay(250);
else if(buttonState2 = LOW)
client.publish("openhab/in/kitchen", "switch2OFF");
// digitalWrite(channel2, LOW);
delay(250);
else if(buttonState3 == HIGH)
client.publish("openhab/in/kitchen", "switch3ON");
digitalWrite(channel3, HIGH);
delay(250);
else if(buttonState3 = LOW)
client.publish("openhab/in/kitchen", "switch3OFF");
delay(250);
// willie button code stops My effort to get the physical buttons to work stops here
// everything below this works
// Change the state of a relay based on the MQTT Message
void messageReceived(String &topic, String &payload)
String msgString = payload;
if (msgString == "switch1ON")
delay(250);
else if (msgString == "switch1OFF")
delay(250);
else if (msgString == "switch2ON")
delay(250);
else if (msgString == "switch2OFF")
delay(250);
else if (msgString == "switch3ON")
delay(250);
else if (msgString == "switch3OFF")
delay(250);
You may note the commented part in the middle, it was my attempt to get this to work. BUt that code only made button1 come on and stay on, and the MQTT status was basically looping all the time.
According to this site link the GPIO’s are the way I declared them, but I may be wrong in the interpretation.
I would really appreciate some guidance. My coding skills are near to non-existant.
THank you in advance.
