as a reader of the forum I want to place a request here because I can’t find anything appropriate to my question:
I have the following setting:
Openhab3
2x Sonoff Touch with 1 channel each
1x Light Bulb
On Sonoff Touch #1 I connected the light bulb
The desired solution should be:
I can control the light bulb from both Sonoff Touch switches. If one switches it ON then the other Sonoff Touch should also go in “ON” state. Then any of the two switches can switch the bulb off again.
I did the following:
Create 2 things for both Sonoff devices
Create a channel on each Sonoff device
create 1 Item Light Bulb
Link both channels to the Light Bulb and assigned profile “Follow” (to follow the state change).
Having this setup leads to an endless flickering of the relais / bulb.
Did I miss something here? Is there anything wrong in my thinking?
The root of the problem. You’ve got three separate devices, which can be in any combination of start states. Try setting up an Item to represent each device to begin with, and when that is working we can look at condensing to less.
Well, actually I have two devices. The Sonoff Touch has an internal connection between the switch and the relais as far as I understand. I’m not sure if I should create either:
Three items (sonoff switch 1, sonoff switch 2, light bulb) having in mind, that the switch 1 and the bulb is practically the same.
Two items (sonoff switch 1 and sonoff switch 2) where sonoff switch 1 is equivalent to the light bulb.
