Sonos binding discovering item multiple times, exception in log
I have a problem with the SONOS binding. The binding discovered all my players and I added them as things (they work). But some players get discovered again.
I also see the following exception in the log:
2021-04-14 15:48:46.241 [ERROR] [y.upnp.internal.UpnpDiscoveryService] - Participant 'org.openhab.binding.sonos.internal.discovery.ZonePlayerDiscoveryParticipant' threw an exception
java.lang.IllegalArgumentException: ID segment 'Table lamp' contains invalid characters. Each segment of the ID must match the pattern [\w-]*.
        at org.openhab.core.common.AbstractUID.validateSegment(AbstractUID.java:98) ~[bundleFile:?]
        at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:76) ~[bundleFile:?]
        at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[bundleFile:?]
        at org.openhab.core.thing.UID.<init>(UID.java:57) ~[bundleFile:?]
        at org.openhab.core.thing.ThingTypeUID.<init>(ThingTypeUID.java:39) ~[bundleFile:?]
        at org.openhab.binding.sonos.internal.discovery.ZonePlayerDiscoveryParticipant.getThingUID(ZonePlayerDiscoveryParticipant.java:97) ~[?:?]
        at org.openhab.core.config.discovery.upnp.internal.UpnpDiscoveryService.remoteDeviceRemoved(UpnpDiscoveryService.java:172) [bundleFile:?]
        at org.jupnp.registry.RemoteItems$4.run(RemoteItems.java:234) [bundleFile:?]
All players are present as things and are working. Shall I report a bug for this.
I’m using OH 3.0.1 on a linux host (ubuntu 20.04).
with kind regards,
Patrik
I think it should be fixed in 3.1 M3.
Great :slight_smile: - thanks
I have a similar issue on OpenHAB 2.5.12 with the Sonos Binding. I don’t get any device discovered and the log says:
2022-01-19 10:54:58.635 [ERROR] [y.upnp.internal.UpnpDiscoveryService] - Participant 'org.openhab.binding.sonos.internal.discovery.ZonePlayerDiscoveryParticipant' threw an exception
java.lang.IllegalArgumentException: ID segment 'Table lamp' contains invalid characters. Each segment of the ID must match the pattern [A-Za-z0-9_-]*.
	at org.eclipse.smarthome.core.common.AbstractUID.validateSegment(AbstractUID.java:97) ~[bundleFile:?]
	at org.eclipse.smarthome.core.common.AbstractUID.<init>(AbstractUID.java:75) ~[bundleFile:?]
	at org.eclipse.smarthome.core.common.AbstractUID.<init>(AbstractUID.java:58) ~[bundleFile:?]
	at org.eclipse.smarthome.core.thing.UID.<init>(UID.java:57) ~[bundleFile:?]
	at org.eclipse.smarthome.core.thing.ThingTypeUID.<init>(ThingTypeUID.java:39) ~[bundleFile:?]
	at org.openhab.binding.sonos.internal.discovery.ZonePlayerDiscoveryParticipant.createResult(ZonePlayerDiscoveryParticipant.java:53) ~[?:?]
	at org.eclipse.smarthome.config.discovery.upnp.internal.UpnpDiscoveryService.remoteDeviceAdded(UpnpDiscoveryService.java:187) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.upnp.internal.UpnpDiscoveryService.startScan(UpnpDiscoveryService.java:168) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:209) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:382) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:367) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:216) [bundleFile:?]
	at org.eclipse.smarthome.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:97) [bundleFile:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_312]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_312]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_312]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_312]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_312]
Is there a chance this gets fixed as well, or is there at least a workaround you could suggest, please?
Thanks a lot.
No there is no plan to publish a patch in 2.5 for that. Maintenance of 2.5.x has stopped more than one year ago. Maintenance is limited for this version to critical security issues that could occur in the openHAB core.
This is fixed in 3.1 and next versions.
