I have configured the SONOS v1.9 binding on my OH1 install and I cant get it working. I have used the Windows UPnP Tester application to get the UUID for the devices, I then configured the devices in the openhab.cfg and then created a simple items file for one player to adjust volume and turn on/off.
Do I have to add anything else, I have read it uses the UPNP library, how can I check if that is installed and running?
I also noticed that the players had _MS on the end of the UUID but none of the examples showed that, should this be included or left off?
I did try restarting, also tried with the _MS removed.
The UDN listed is not my actual UDN, I just changed it all to zeros for the forum, thanks for the links I will check the UDN from there to see if it matches.
