If SonosBadezimmer_Standalone ist a switch-item it sould work. It would be easyer knowing your definition.
You can use the RestAPI for checking a item-state.
Alternate SonosBadezimmer_Standalone.sendCommand(ON)
It is set to on, but the expected action, which I would believe is to drop from the zone player group, is not happening. It doesn’t change on a grouping change either. When I add the zone to a zone group, the switch remains “ON”.
I understand that not all of the Sonos commands are working right now. Is there a list of commands which are not working with the current Sonos firmware somewhere?
Yes, it is defined as a switch item, but no, it doesn’t work. I can change the switch and nothing happens. Somewhere in these forums I read that some Sonos binding commands that relied on undocumented status pages were broken at some point due to changes in firmware. The current status is a bit unclear to me.
At my knowledge, the binding is not relying on any undocumented status pages but only on UPnP actions. Of course Sonos could decide at any time to suppress some UPnP actions with any new firmware.
Will try to test again the standalone command when I find time.
Hi, The UI switch (Paper UI) works for me as well. I am calling the switch in a rule though. I think the problem is, that when you group a zone, it is no longer “Stand Alone” and the switch should change to “OFF”. However it doesn’t. After my first usage of the sendCommand(SonosBadezimmer_Standalone, “ON”), the switch will stay on indefinitely no matter what. So in Paper UI, I first had to set the switch to “OFF” manually, although the zone was grouped. Then switching it to “ON” would ungroup as expected.
After grouping, the switch stays “ON”, although the player is not really “stand alone”. So any subsequent command “ON” will not register any change on the switch and thus no action. This would be no problem as long as the zone still is standalone. But because after grouping the zone, the switch will not change, sending the “ON” command won’t cause it to ungroup as expected any more.
For now, my work-around is to first send “OFF” then “ON” in order to invoke the ungrouping.
This switch is only a kind of trigger or command if you prefer. It does not show if the player is in standalone mode or not, a change of its state will just start the action.
Note that you can send either ON or OFF to trigger the action.
That is not the issue. I am not trying to read the switch!
I want to invoke the switch. The problem is, that in order to invoke the switch, you need to change its status from whatever it was. It would be logical that the switch would either revert to “OFF” as soon as the player is joining a group (thus no longer standalone) or that it would revert to “OFF” as soon as it has executed the command, i.e. a momentary switch action.
The way it is now, you have to know what the last command to the switch was to effect the “stand alone” command. If you send “ON”, while its value was “ON” already, then nothing happens. So now I have to send both values, only to be sure that an action is triggered. Or I would have to first poll for the switch position and then reverse it, which would also be two operations to invoke one command.
So the bug is “This switch invokes a momentary action, but does not have a momentary operation”. It sticks in the last position without this having any logic, meaning or predictability.
What you say is not stupid but this was not implemented like that in the Sonos binding and it concerns many channels, in fact probably all channels with access mode “W” in the documentation. As another example, you can use the channel to play a playlist. This channel remains with the value you set.
Are you sure that sending a ON command to a switch inside a rule does nothing if the switch is already in an ON state ?
I have done some testing, and actually you are right. I can send either command and it still works no matter what the status was.
Then I must have some other problem. My rule logic is that whenever there is motion in the bathroom and Sonos is not already on, that it will either play nature sounds or in case my playbar is playing TV sound, group with the playbar. I always send the “stand alone” command right before I set the volume, playmode and trigger the nature playlist. They always go together in that order.
My symptom is: after watching tv (and having triggered the grouping with the playbar), I go into the bathroom and I get nature sounds on both the bathroom and the playbar. That should not be possible as I always issue the standalone command before playing back nature sounds. There is no manual control of Sonos in between. So I was figuring the standalone command fails. Maybe some kind of race condition between the zone dropping and playlist start?
Or maybe some kind of race condition between the zone status saving and the grouping, causing it to restore the grouping later?
var Timer music_bath_timer = null
var Boolean music_bath_motion = false
rule "TV Sound Automation"
//Rules when TV is producing sound
Item SonosFernseher_State changed
if (SonosFernseher_Currenttrackuri.state.toString.contains(":spdif") && (SonosFernseher_State.state == "PLAYING")){
//As the playbar is in the same room as the hifi sonos system, we pause the hifi system on TV sound
sendCommand(SonosWohnzimmer_Control, PAUSE)
rule "Start playback on movement"
//rules for movement in the bathroom
Item BewegungssensorBadezimmer_SensorOccupancy changed
if (BewegungssensorBadezimmer_SensorOccupancy.state == ON){
if ( SonosBadezimmer_State.state != "PLAYING" ){
//Sonos in in Bathroom not in use, save state, adjust volume, and set variable to indicate playback is caused by motion
sendCommand(SonosBadezimmer_Save, "ON")
//TV is producing sound, link to Playbar
sendCommand(SonosBadezimmer_Volume, 25)
sendCommand(SonosFernseher_Add, "RINCON_000E5810648001400")
else {
//No TV, start nature sounds
sendCommand(SonosBadezimmer_Standalone, "ON")
while (SonosBadezimmer_Localcoordinator.state == OFF){
Thread::sleep(200) //wait for zone to become (probably) standalone
sendCommand(SonosBadezimmer_Shuffle, "ON")
sendCommand(SonosBadezimmer_Playlist, "nature sounds")
sendCommand(SonosBadezimmer_Repeat, "ALL")
music_bath_motion = true
} else {
//Someone in bathroom, music is playing, destroy timer to prevent sound stopping
music_bath_timer.cancel
else if ( (BewegungssensorBadezimmer_SensorOccupancy.state == OFF) && (music_bath_motion == true) ){
//no movement, playback was triggered by movement. Set timer to stop playback
music_bath_timer = createTimer(now.plusMinutes(5)) [|
sendCommand(SonosBadezimmer_Control, PAUSE)
sendCommand(SonosBadezimmer_Restore, "ON")
rule "Cancel autostop after manual control"
Item SonosBadezimmer_Control received command or
Item SonosBadezimmer_Volume received command
//in case things are changed manually, assume no autostop is desired.
if (music_bath_motion && ( SonosBadezimmer_State.state == "PLAYING" )) {
I added a little loop to wait with the playlist command until the bathroom is the local coordinator. That should take care of most situations. I’ll add in into the above code just in case anybody thinks nature sounds and TV in the bathroom is a nice idea, and wants to reuse the logic. It gets complicated quickly if you want to cover all eventualities. I’ll add some english comments as well.
