Just wondering if anyone has found that the sonos clearqueue channel works? My Sonos binding generally works fine, but setting a clearqueue switch to ON doesn’t do anything.
I’m assuming this is a bug. Until it gets fixed, hacky workaround number 57 is to install the python sonos library and then create a tiny python script to clear the queue:
#!/usr/bin/env python
from soco import SoCo
import sys
if __name__ == '__main__':
sonos = SoCo(sys.argv[1])
sonos.clear_queue()
I just tested and it is working perfectly for me.
I have tested through UI.
Check that your rule is correct called, and that your item is really updated looking at the event logs.
Any update on this? Running most recent release version and clearqueue doesn’t always work (though sometimes it does). Don’t see any errors or anything and seems to be hit or miss on all my devices (Play:1, Play:5, Connect, One)
