I’m just getting started with Openhab2, so I hope I’m not missing something.
I’ve gone through the worked example, and have a sitemap, with a KNX switch and a network port.
However, I thought I’d try to add my sonos speaker to this item, but it refuses to show up in the site-map.
The auto-search works, and I can play to the device, so I’m happy that is working in principle, it’s just my site-map that is problematic.
This is my configuration:
Beagle bone black running Ubuntu 16.04
Openhab2 (Installed via apt-get last week)
default.things:
Thing sonos:CONNECTAMP:living [ udn=“RINCON_B8E937AE9BC601400”, refresh=60]
Note: this seems to be working, since it’s showing up in the paper-ui, and I’ve deleted it’s auto-find item.
default.items:
Switch Presence_Mobile_Will “Wills Iphone” { channel=“network:device:192_168_1_64:online” }
Switch Lighting_test “Lighting 1” { knx = “<1/0/4” }
Switch Sonos_Livingroom_Playqueue “Play Sonos Queue” { channel=“sonos:CONNECTAMP:living:playqueue” }
Switch Sonos_Livingroom_LED “Play Sonos Queue” { channel=“sonos:CONNECTAMP:living:led” }
Note: The first two switches appear to work, but the second don’t appear anywhere. I also get no warning/errors in the /var/log/openhab2/openhab2.log file
default.sitemap:
sitemap default label=“My first sitemap”
Switch item=Presence_Mobile_Will label="Wills Mobile"
Switch item=Lighting_test label="Test Switch"
Switch Sonos_Livingroom_Playqueue label="Play Sonos Queue"
Switch Sonos_Livingroom_LED label=“Play Sonos LED”
Note: The first two items appear, but the second two don’t appear.
I don’t get any warnings or errors, so I’m a touch confused. Any pointers how to enable better logging?
Any suggestions?
