Sorry for the question, but I’d like to know if it’s normal to have this infinite loop when setting a refresh value in the Sonos Binding Debug Trace:
2017-02-05 20:07:20.751 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.751 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.762 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.763 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.764 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.765 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.765 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.766 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.767 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.768 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.769 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.769 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.772 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.773 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.774 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.775 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.776 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.776 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.777 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.778 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.779 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.780 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.782 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.783 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.784 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.785 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.786 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.788 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.788 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.789 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.789 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.797 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.798 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.798 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.799 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.799 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.800 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.800 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
2017-02-05 20:07:20.802 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
and this is only an extract of 50 milliseconds
Is it normal? Do you have the same trace with OH2.1 snapshot (or OH2 Release)?
If not, do you know the source of this issue and how to solve it?
Regards
