Hi Patrick,
I set it to
8086
I’ve tried another port but in my case it still did not work.
BR
/Franz
Hi Patrick,
I set it to
8086
BR
/Franz
OK, thought maybe you have used another port but that’s the default and I still can’t see how that interferes with UPNP.
Anyway, to get rid of my virtual machine, I now installed the second openhab instance on a raspberry pi. I have one running pihole and I just installed openhab on that one. I only have the Sonos things / items and connect to the main openhab installation via the remote binding. Solves it for me.
Hi.
I’m struggling as well with this issue.
I’m trying to make openhab 3.2.0.M4-debian work from Docker.
I’ve updated log4j2.xml to increase jupnp log level to WARN.
<Logger level="WARN" name="org.jupnp"/>
In the logs I receive this messages:
2021-11-26 12:40:14.796 [WARN ] [p.protocol.RetrieveRemoteDescriptors] - Device descriptor retrieval failed, no response: http://xxxxxxx:8200/rootDesc.xml
2021-11-26 12:40:35.777 [WARN ] [p.protocol.RetrieveRemoteDescriptors] - Device descriptor retrieval failed, no response: http://yyyyyyyy:1400/xml/group_description.xml
xxxxxx and yyyyy are the IP addresses of a DLNA MediaServer and a Sonos device. From within the openhab container, I can successfully curl to both this urls.
In my case, running influxdb with network_mode host vs with port 8086 exposed doesn’t make a difference.
I’m using pfSense as router and I’ve added a LAN rule to specifically allow LAN 1400 and 8200 ports, just in case.
The only difference in my case is that I added a nginx reverse proxy to the stack.
@FranzS - Do you have this working by just setting the influxdb network mode to host?
EDIT: @pgruetter - I’ll have to implement your workaround for now. Thanks.
The workaround helped for me as well, however I had to apply it to some other containers too like telegraf, grafana, etc. Thanks guys!
