Hi all,
Bit of help on this one please.
I have a rule that works perfectly, except for one thing.
It runs on an alexa command, it turns a smart plug on, gets a Sonos playlist, controls the volume and then plays the playlist…perfect…
However, if the opposite alexa command is called, the plug switches off as designed but the STOP command on the sonos speaker does nothing…any ideas? I’m sure the syntax is correct but do I need to get it to refer to the playlist again or something? I assumed that the STOP command just stops whatever is playing???
rule "Alexa command Bedtime is called"
Item aBedtimeRoutine changed
if(aBedtimeRoutine.state == ON)
logInfo(logName, "Bedtime routine called by Alexa")
MyPlug.sendCommand(ON)
sendCommand(Sonos_EB_PlayPlaylist, "12345")
sendCommand(Sonos_EB_Volume, "6")
sendCommand(Sonos_EB_Control, PLAY)
else
logInfo(logName, "Awake routine called by Alexa")
MyPlug.sendCommand(OFF)
sendCommand(Sonos_EB_Control, STOP)
