I’m using the stable 2.2.0 release and I don’t get any errors…
However I can’t even setup the IRCC, and other channels (just the SimpleIP). Restarting the TV and openHab doesn’t help, the discovery can’t find the device.
This is not my main TV and I can live with that I can only use the SimpleIP, because it has all the functionality (turning on-off, channel change, etc…) which I need, but this is really prevents using this binding that TV turns off completely after a few mins. And I think this is not the problem of the binding, because as soon as I turn the TV on from the remote control it connects to the TV. Years before I have tried a mobile app for this TV, but as I can remember it had this same problem, that I was unable to turn on the TV after not using it for ~10 mins.
I just saw that there is a value for which network adapter is used. However is it not so clear that this is the adapter of the TV or how the openhab server connects to the router?
I just want to ask that there will be any new to this binding in the new 2.3 stable release? If I’m currently on 2.2?
Also do you have any idea to this problem which I have?
Since then I have restarted several times the TV and openHab as well, but still can’t find it, just simple ip tv works… also it get’s disconnected after I turn TV off.
My bining is working nicely even at 2.3.0.
My binding is still at RQST code mode. But it works.
The only issue i have is that my changes of the ignored channels are not saved.
That’s kind of annoying because i don’t want the binding to ignore any …
Maybe this issue goes along with the not saved ignore-configuration.
I don’t know how to get my tv to provide a code i could enter there …
yes. everything’s fine except the issue i mentioned above.
i control: power, volume, amazon, twitch, all channels and even IRCC commands.
if you like i can share my items file
Hi, i deleted the scalar web thing since I had problems connecting to my TV. I would have hoped for it to show up in the inbox. But to add it as a thing again, I seam to need to manually enter IP, MAC, CODE and MAP. I don’t have a map. Is there a more user friendly way to get Scalar web to work with my Sony TV again?
I think not. I am considering my options for getting my vW760 to work with oh, and afaict, the only available option is to write a new dedicated binding. I am tempted, but I fear my java knowledge will mean it will take forever.
Maybe someone has already done something for the Sony projectors? (Open call)
I’m still here - just haven’t touched this in awhile (had some health stuff happen that has created an extended leave). I still plan on getting back to it because the latest version is a HUGE change over what you all have.
Man i’m really new to all of this.
I need some help.
I have a Sony TV (from 2018 model) and i managed to run openHAB and my motion sensors are up and running.
Now i need to find a way to controll my TV.
How to discover it ?
How to controll it?
What is a good “sitemap” for TV controll?
What happens when i plase an “addon” in the /addon folder?
How to see if something is working?
I plased an “org.openhab.binding.sony-2.0.0-SNAPSHOT.jar” file there.
So what now ?
How to test?
Do i need to go in localhost and discover it ?
Maybe add same addon from there?
